Community Member
Difference between PCD and PC Assurance
What's the difference between Prime Collab Deployment (PCD) and Prime Collab Assurance and Analytics or Prime Collab Provisioning??
PCD contains all 3 applications??
Juan Carlos
1 ACCEPTED SOLUTION
Purple
Hi Juan, Basically, Prime
Hi Juan,
Basically, Prime Assurance ,Provisioning and PCD are three different applications.
PCD is used for migration of Call Manager clusters from version 6, 7, 8 to version 10 on VM servers.
Assurance is used for real time monitoring of devices like IP phones, Gateways, get inventory reports.
Provisioning is used for Day 2 support for managing users[ add , delete , change]. Users can do forward, speed  dials , change passwords.
regds,
aman
Purple
Hi Juan,
regds,
aman
Community Member
Hello Aman, thanks for your
Hello Aman, thanks for your comments.
220
