03-10-2017 06:24 PM
I trying to do a migrate with PCD 11.5 and I get this error: An error occurred while displaying the data returned from Cisco Prime Collaboration Deployment: obj.entities is null. This usually means the data returned was missing some critical pieces of information.
03-12-2017 04:41 PM
PCD has some problems with passwords and special characters, passwords longer than 16 characters and it seems that if "iV" is in the password, or starts with, it might also cause problems.
03-13-2017 05:38 AM
My Esxi password is no longer than 16 characters and my PCD version (11.5.3) dont' match with the bug.
03-13-2017 09:54 AM
What about your CUCM and the other UC app servers??
If the answer is still no, then only the logs would provide more info on what's causing the issue.
03-13-2017 09:57 AM
CUCM is version 8.6.2
Presence is version 8.6.4
03-14-2017 08:46 PM
03-15-2017 08:01 AM
Other thing. Esxi is version 6.0
09-25-2017 08:18 AM
Greetings,
Did you get this fixed? If so, can you provide solution.
