11-14-2006 03:32 AM
Hi.
We have seen that there are a feature that recover the PPPoE sessions closed in one side and up in the other. This feature is called 'PPPoE Session Recovery After Reload '.
In the feature navigator, we can see that this feature is available for 7200 series. It seems not available for 10000.
But in the release notes of Cisco IOS 12.3(7)XI3,
http://www.cisco.com/en/US/partner/products/hw/routers/ps133/prod_release_note09186a008040929e.html
appears this bug as resolved:
CSCsa46626
PPP PADT messages are not sent by a PPPoX PTA router to a client when the PPPoX user is no longer connected to the PPPoX PTA router.
This feature is enabled only within the BBA Group configuration using:
bba-group pppoe pppoe1
sessions auto cleanup
This issue can occur when a Cisco 10000 Series router is used as a PPPoX PTA router, and there has been a network flap causing the PPPoX users to lose their connections. PPPoE will experience this issue when BBA Groups are in use. VPDN Group configuration does not support this feature.
There are no known workarounds.
We have tested the IOS 12.3(7)XI6, but the router (10000) doesn't send the PADT (auto cleanup). In 7200, it works correctly.
Anyone have has this problem?
Anyone can confirm if this feature is supported?
Regards.
Jose
Solved! Go to Solution.
11-17-2006 09:23 AM
Hi Jose ,
I checked it using feature navigator and noticed that cisco 10000 doesn't support ""PPPoE Session Recovery After Reload"" feature.
The following platforms support the feature.
1700
1800
2600
2800
3200
3600
3700
3800
7200
7301
7400
satish
11-14-2006 04:14 AM
Hi ,
Is it possible to check it with 12.3(7)XI8d or 12.3(7)XI7.
Thansk,
satish
11-14-2006 06:08 AM
Hi Satish.
Thanks for your rapid response.
It's dificult, because these boxes are working correctly with this IOS version and have many customers. Then we have to confirm that it will work before upgrade.
Have you seen this command working in this type of box (10000)?
Regards.
Jose
11-14-2006 06:27 AM
Hi Jose ,
I will try to get you some document regarding sessions auto cleanup on 10000.
I am searching for the document and i will post it soon.
satish
11-17-2006 08:37 AM
Hi Satish.
Has you found any document regading this feature in 10000?
Thanks and regards.
Jose
11-17-2006 09:23 AM
Hi Jose ,
1700
1800
2600
2800
3200
3600
3700
3800
7200
7301
7400
satish
