09-26-2005 02:32 AM
Hi all, I have a very strange problem. I have 4 isdn modems (3com ISDN Pro-TA) connected to the 4 interfaces. Suddenly i can't dial into 2 of the modems. On one of the serial I have a sign of the connection, on the other nothing is logged. This is the log from the first:
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
715 input errors, 0 CRC, 715 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
I tested all the modems on one interface, I tested all interfaces with one modem, and I tested all cables, and everything seems ok. But when I connect all 4 modems I get connection errors.
Please help.
09-26-2005 02:51 AM
I assume you have two WIC-1B-S/T cards installed in your router ? Can you post your configuration, as well as the output of 'show version' ?
GP
09-26-2005 11:56 PM
No, I have two WIC-2A/S cards installed. This is the output from show version and the config file is in the attachment.
IOS (tm) C1700 Software (C1700-Y-M), Version 12.3(2)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 02-Sep-04 21:09 by eaarmas
Image text-base: 0x80008120, data-base: 0x80ABE20C
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.3(2)T8, RELEASE SOFTWARE (fc3)
ZV_Skopje uptime is 20 hours, 47 minutes
System image file is "flash:c1700-y-mz.123-2.T8.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 28342K/4426K bytes of memory.
Processor board ID FOC063502R4 (3065634168), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
4 Low-speed serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
I was already discussing this problem with Zulfiqar Ahmed and we diagnosed that it is a hardware failure, but I after I tested every single component of the system I had to write again. Here is the thread link if needed.
09-27-2005 02:06 AM
at first glance, I would say there might be contention for the interfaces, that is, you have more logical (dialer) interfaces than you have physical interfaces. Your Dialer 0 can only use Serial3, but that serial interface is configured for pool 1 and 2, which means it can be used by all the other 5 dialer as well.
Can you try and make all 4 serial interfaces members of both pools ? Then configure the command 'dialer fast-idle 1' on all the dialer interfaces, which would release the line almost immediately if there is contention between connections.
HTH,
GP
09-28-2005 02:48 AM
I finally located the problem!
The problem is that the modems connect at 128k, and after that the other modem doesn't work. I tried to lock the modem speed at 64k but no success.
I read on the usr modem manual the at string for 64k is
PPP_64K: AT*VI=0*VO=5*PPP=1S67=0
I tried with adding DTE:*VI=0*VO=5*PPP=1S67=0 in the modemcap entry, and MSC:*VI=0*VO=5*PPP=1S67=0 but either way with no effect, the modem pickup the line with 115200. Is there any way to fix this?
