Community Member
2511 hangs after opening port
I have been struggling for some time now trying to get my 2511 to connect through the octal cable to my other devices. All I get is trying router1....open, but I get no access to the devices on the other side of the connection. Please help.....I have included the config and log for review.
2511-1#router1
Translating "router1"
Trying Router1 (172.16.1.1, 2001)... Open
Community Member
Re: 2511 hangs after opening port
try transport input all instead of transport input telnet.
Community Member
Thaks for your help, but I have tried that and also tried it again after your suggestion. Still have the same problem.
Community Member
Not sure if this will help, but here goes:
set the line for:
transport output telnet
Try reverse telnet to your router from another device (PC)
ie >telnet 172.16.1.1 2001
If this does not connect, try setting the line for the following:
line 1/01
no exec-banner
modem InOut
no exec
transport input all
transport output all
escape-character NONE
221
