2811(NM-8AM) does not answers incoming call from PC
Dear friends,
We are planning to setup an out of band management connectivity, in our test setup we have a Cisco 2811 ISR (with IOS 12.4(9)T5 ) with NM-8AM (Analog modem module) installed.
Test Setup:
1. One Analog line (PSTN) connected to PC via built-in modem
2. Second Analog line (PSTN) connected to Cisco 2811 (NM-8AM) terminated on the analog modem module
3. Both the analog lines are working fine.
Test Scenario:
1. The router should accept the incoming call from PC. And from the PC we should be able to telnet into the router via dial up connectivity (Out of band)
Test procedure:
1. The Cisco 2811 router is configured as follows:
version 12.4
hostname Dial-Up-CPE
boot-start-marker
boot-end-marker
logging buffered 16384 debugging
enable password cisco
ip cef
voice-card 0
no dspfarm
username cisco password 0 cisco
interface Loopback0
ip address 10.10.10.1 255.255.255.255
interface FastEthernet0/0
ip address 20.20.20.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
peer default ip address pool DIALIN
ppp authentication pap chap
group-range 1/0 1/7
ip local pool DIALIN 172.16.16.1 172.16.16.5
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
exec-timeout 0 0
line aux 0
exec-timeout 0 0
password cisco
modem InOut
transport input all
stopbits 1
speed 38400
flowcontrol hardware
line 1/0 1/7
modem InOut
transport input all
stopbits 1
line vty 0 4
password cisco
scheduler allocate 20000 1000
2. With the above configuration, the router is not able to answer the incoming call from the PC.
3. And from the PC we are able to dial to a PSTN number at the router side, PC gives a proper dial tone and once the number is dialed, the call is landed on the other side (router end) and it rings continuously. But, the router does not answer this incoming. The analog line at the router end is terminated on async interface 1/0.
As I am new to dialup connectivity with NM-8AM, Could some please suggest the proper configuration in our router configuration OR Are missing any commands?
Any links/references would be of great help.
Thank you
Pradeep
1 REPLY
Re: 2811(NM-8AM) does not answers incoming call from PC
I guess I'm having exactly the same setup. The integrated modem on the other end does pick up the call but soon disconnect after displaying "Waiting for carrier".
Any clue?
Eyad
263
