2811- PVDMII-24D, login issue
I'm trying to set up a 2811 as modempool with Dialout/Ez on the client. The problem is that the connection is terminated upon establishing the connection.
Sometimes it doesn't even show the login prompt to the remote RAS-server, and other times a login is possible and a few packets can be sent before it terminates.
Andreas
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 2811- PVDMII-24D, login issue
likely you do not have clock configured correctly, please configure:
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
Please rate post if it helps!
Thanks, it did the trick and sorry for not RTM.
Kind Regards
Andreas
Sometime the manual is not very useful in saying what is really needed and what is not.
Thanks for the appreciation and good luck.
297
