03-25-2006 03:26 AM
DEar all,
I have a 2811 router with the c2800nm-ipbase-mz.123-8.T10.bin IOs..
I have a VWIC-2MFT-G.703 card terminated on wic 0 slot..
I am not able to configure the PRI on that..
It takes all the commands required for PRI enabling but for D-channel one I configure the encap as PPP my channel goes down..
I am forwarding following outputs ..
Plz Help.
network-clock-participate wic 0
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-net5
controller E1 0/0/0
controller E1 0/0/1
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/0/1:15
no ip address
no cdp enable
interface Serial0/2/0
no ip address
shutdown
no fair-queue
clockrate 2000000
interface Dialer10
ip address 139.158.79.85 255.255.255.252
dialer pool 10
dialer idle-timeout 2147483
dialer string 02240057435
dialer-group 1
interface Dialer20
description ** 128K ISDN Link to Bangalore-IST *
no ip address
encapsulation ppp
shutdown
dialer pool 20
dialer caller 42291633
ip classless
ip http server
dialer-list 1 protocol ip permit
contro-plane
once I configure s0/0/0:15 as encap PPP
plz note the following output
Pri-Router#sh isdn sta
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/1:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
one i remove PPP encap...
It shows Multiple_Frame_Established..
Cud any bode plz tell me whether 2811 with WIC slots and IOS mentioned above supports that configuration or not...
or this card work on that slots or not..???????????????
Urgently needed the answer...
03-30-2006 07:53 AM
03-30-2006 11:02 AM
hi farhan.javed
try to perform a (debug isdn q921) and (debug dialer)
to see exactely what is happening,
i guess you forgot
dialer pool-member 10
dialer pool-member 20
on the physical interface Serial0/0/1:15
hope this help
04-03-2006 01:56 AM
Well there is a problem with ur config.
Pls add "encapsulation ppp" and ppp authentication chap" on your Serial 0\0\1:15 (D-channel) and also on Dialer10.
PPP authentication is also missing on ur Dialer20.
Pls revert back if problem still persists.
