Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
2811 w/CableDocsis and AP-AG card not recognized
Just purchased a 2811 router with voice and wan cards. The voice cards pick up fine. For whatever reason, can't recognize the HWIC-Cable card and the HWIC-AP-AG card. with a show diag I get the following
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
This happens for both cards but the voice cards come up fine. Have tried swapping the cards/slots around to no avail.
Currently running
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
which I believe should support these HWIC cards. Anyone have any idea as to why I can't get either of these WAN cards to recognize in this 2811 ? Thanks.
Silver
Re: 2811 w/CableDocsis and AP-AG card not recognized
The Motherboard WIC slots are numbered from 0 to 3 and the Cisco cable HWIC is supported in the WIC slots of Cisco IAD2431.
If you want to know more please click the following link:
http://www.cisco.com/en/US/products/hw/routers/ps282/products_tech_note09186a008035b051.shtml
Hall of Fame Super Gold
No, 12.4(3g) does not supports your cards.
The cable card is supported in 12.4((6)XE that should also support the AP card, introduced in 12.4(2)T.
Hello found that also 12.4(11)T supports both cards an would be a betterchoice as it not life-limited train like XE.
146
