Community Member
2851 PRI analogue dialin
I have a Cisco 2851 with a NM-1CE1T1 PRI interface that I wish to utilise for dialin. I have followed some configs on here, however cannot workout the correct line commands.
If I try to add a line via i get an error that it is not supported in hardware - no physical hardware support for line XX.
If I do a show line I get the following output -
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 0 CTY - - - - - 0 0 0/0 -
1 1 AUX 9600/9600 - - - - - 0 0 0/0 -
322 322 VTY - - - - - 0 0 0/0 -
323 323 VTY - - - - - 0 0 0/0 -
324 324 VTY - - - - - 0 0 0/0 -
325 325 VTY - - - - - 0 0 0/0 -
326 326 VTY - - - - - 0 0 0/0 -
327 327 VTY - - - - - 0 0 0/0 -
328 328 VTY - - - - - 0 0 0/0 -
329 329 VTY - - - - - 0 0 0/0 -
330 330 VTY - - - - - 0 0 0/0 -
331 331 VTY - - - - - 0 0 0/0 -
332 332 VTY - - - - - 0 0 0/0 -
333 333 VTY - - - - - 0 0 0/0 -
334 334 VTY - - - - - 0 0 0/0 -
335 335 VTY - - - - - 0 0 0/0 -
336 336 VTY - - - - - 0 0 0/0 -
337 337 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
2-321
my config is attached.
1 REPLY
Silver
Re: 2851 PRI analogue dialin
You need to define "group-range x y" under your group async.
153
