Community Member
3030 VPN Concentrator / Need help with purchasing router for remote office.
We have just recently aquired a new site that will need connectivity to our main network with the use of a broadband connection and our 3030 VPN Concentrator.
I have about 10 users, and a another WAN that will need to be routed internally. I would like the router/switch/vpn to connect to the VPN 3030 at our main site instead of using the VPN client on each machine.
Any ideas on which product would be the best solution in my scenario?
I've already tried a Nortel Contivity 221 that was just laying around here, but it won't connect plus the support from Nortel isn't that great.
Stephen
Hall of Fame Super Gold
Re: 3030 VPN Concentrator / Need help with purchasing router for
Can you clarify about on the other WAN to be routed internally, wich kind of interface does it have ?
That is key to decide the right product.
You should go for "Cisco 800 Series integrated services routers "
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
Or
Cisco 1800 Series integrated services routers
http://www.cisco.com/en/US/products/ps5853/prod_models_comparison.html
Hope that helps !
Jagdeep
Pls rate if that helps !
145
