3640 on ROMMON MODE
I shut down my 3640 router which i use for RAS access and now when i power it up it goes into ROMMON mode,any suggestions on how to get it back to it's normal operating mode without losing the configs on the box..?
Re: 3640 on ROMMON MODE
Follow the steps here http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a008009429f.shtml
Let us know the outcome.
Dandy
Hall of Fame Super Silver
The link posted by Dandy has helpful information. If that does not lead you to a solution then I would suggest that you post all the console messages that appear during an attempt to boot the router. The console messages may show what the problem is and point toward a solution.
Rick
This same question is posted in the LAN Switching and Routing forum. I suggest that any further discussion of this be consolidated in the LAN forum.
Rick
150
