Bronze
4G EHWICS Finally arrived! Now how to configure...
Hey All,
My long-awaited 4G EHWICs have arrived for my ISRG2 routers. We've gotten SIM cards from Verizon Wireless that have been activated and now i'm trying to make the card work.
I've followed the instructions at this link:
www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/EHWIC-4G-LTESW.html
to do a very basic config, but my interface is still not working correclty.
IOS: 15.1(4)M4
Platform: 2911 SRST/K9
Question 1: Anyone know why my interface shows up as four interfaces on one EHWIC?
yourname#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down dow
GigabitEthernet0/0         10.10.10.1      YES NVRAM  down                  dow
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down dow
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down dow
Cellular0/0/0              unassigned      YES NVRAM  up                    up
Cellular0/0/1              unassigned      YES unset  down                  dow
Cellular0/0/2              unassigned      YES unset  down                  dow
Cellular0/0/3              unassigned      YES unset  down                  dow
Loopback0                  192.168.1.100   YES NVRAM  up                    up
NVI0                       192.168.1.100   YES unset  up                    up
yourname#
Question 2: What am I missing?
chat-script lte"" "AT!CALL1" TIMEOUT 60 "OK"
interface Loopback0
ip address 192.168.1.100 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Cellular0/0/0
ip address negotiated
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
ip nat inside source list 1 interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
access-list 1 permit any
dialer-list 1 protocol ip list 1
line 0/0/0
script dialer lte
modem InOut
no exec
DEBUG:
yourname#debug dialer
Dial on demand events debugging is on
yourname#debug chat
Chat scripts activity debugging is on
yourname#ping 4.2.2.2 source lo0
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.100
May  3 15:30:55.383: Ce0/0/0 DDR: re-enable timeout
May  3 15:30:56.943: Ce0/0/0 DDR: place call
May  3 15:30:56.943: Ce0/0/0 DDR: Dialing cause ip (s=192.168.1.100, d=4.2.2.2)
May  3 15:30:56.943: Ce0/0/0 DDR: Attempting to dial lte
May  3 15:30:56.943: CHAT0/0/0: Attempting async line dialer script
May  3 15:30:56.943: CHAT0/0/0: Dialing using Modem script: lte"" & System scrip
t: none
May  3 15:30:56.943: CHAT0/0/0: process started
May  3 15:30:56.943: CHAT0/0/0: Asserting DTR
May  3 15:30:56.943: CHAT0/0/0: Chat script lte"" started
May  3 15:3.0:56.943: CHAT0/0/0: Expecting string: AT!CALL1..
May  3 15:31:01.943: CHAT0/0/0: Timeout expecting: AT!CALL1
May  3 15:31:01.943: CHAT0/0/0: Chat script lte"" finished, status = Connection
timed out; remote host not responding
May  3 15:31:01.943: Ce0/0/0 DDR: disconnecting call.
Success rate is 0 percent (0/5)
yourname#
Bronze
Figured it out. Was missing a space in the chat script.
Hey man, Im running into the same issue.  Cant seem to understand whats wrong with mine.  My profile is inactive.  Do yoiu have a way to fix it?
Finally got one too. We ordered it last november. Quick question for rtjensen4. In the configuration doc it states that you need a username/password for data provisioning. Did you acquire that from verizon?
Example:
router#cellular 0/0/0 lte profile create 2 apn.com chap username1 password1 ipv4
  Scott
Bronze
Re: 4G EHWICS Finally arrived! Now how to configure...
Nope, actually skipped the whole profile part, the default profile worked fine.
Thanks! That worked for me too.
Where was the missing space in this config.  Im having the same trouble.
If you copy and paste the following you will be good to go.  You will simply need to add route statements from this point forward
chat-script lte "" "AT!CALL1" TIMEOUT 60 "OK"
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
dialer-list 1 protocol ip permit
line 0/0/0
script dialer lte
modem InOut
no exec
In rjensen4's config there wasn't a space after the lte.
So for example the chat scrip had
instead of
12834
