Webcast-Catalyst9k
501 port forwarding
I have a cisco 501 at one of our remote offices. I have read some of the posts from others, but I still can't get into our remote security system that uses ports 554 through 557, tcp udp. I have pasted some of the config below, hoping that someone can tell me what I am missing, or have done wrong. The inside IP of our security system is 192.168.1.150
PIX Version 6.3(5)
names
object-group service OfficeSecurity tcp-udp
port-object range 554 557
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 110 permit tcp any interface outside eq https
access-list 110 permit tcp any object-group OfficeSecurity interface outside object-group OfficeSecurity
access-list 110 permit udp any object-group OfficeSecurity interface outside object-group OfficeSecurity
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xx.xxx.xxx.xxx 255.255.255.224
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface 554 192.168.1.150 554 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 555 192.168.1.150 555 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 556 192.168.1.150 556 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 557 192.168.1.150 557 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 554 192.168.1.150 554 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 555 192.168.1.150 555 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 556 192.168.1.150 556 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 557 192.168.1.150 557 netmask 255.255.255.255 0 0
access-group 110 in interface outside
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 68.248.119.129 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
1 REPLY
Re: 501 port forwarding
Your acl 110 is too restrictive. You want to allow access to the specified ports but it is unlikely that the source port will equal the destination port.
ACL 110 should be:
access-list 110 permit tcp any interface outside object-group OfficeSecurity
access-list 110 permit udp any interface outside object-group OfficeSecurity
Hope this solves your problem, I did not find any other likelly issues so this might as well be it.
Leo
234
