Webcast-Catalyst9k
7200 Redundant Configuration ATM/PRI
I have a question regarding the possibilities of a redundant Router config.
At the moment we have a 7206VXR wit a 155 Mbit ATM Link, a PRI and the Gigaethernet.
We would make redundant this machine..
My question: What is the best practice to do this?
I thought to make the following:
An identical 7200 Router.
For the switchover of ATM I can use the APS feature.
For the PRI I use the same number on both PRI and use Multichassis Multilink PPP between the two Routers.
On the LAN (GigEth) HSRP or VRRP.
Can this work? Have anyone a better idea or suggestions?
Thomas
1 REPLY
Re: 7200 Redundant Configuration ATM/PRI
Can you revert back on which interface you are terminating the ATM Link ??
AFAIK and from my personal exp APS works well with the POS interfaces..
regds
218
