857 ADSL problems
I am having problems connecting over ADSL using an 857W router in the UK. My provider is Demon. Is anyone else having problems?
Config used is below,
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
description $ES_WAN$$FW_OUTSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface Dialer1
description $FW_OUTSIDE$
ip address xxxxxxxxxxxx
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect fwrule out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxxx
ppp chap password xxxxxxxxx
Re: 857 ADSL problems
What kind of problem do you have?
Do you have a link (CD led on)
If so, verify the vp/vc setting with the ISP and issue the "debug ppp neg" command to check for possible negotiation issues.
Leo
I changed the ATM interface from dsl operating-mode 'auto' with ansi-dmt as suggested.This seemed to improve connectivity as the CO led remained solid for 30s before dropping off.
debug logs below. Dialer debugs look most promising
Thanks for your help.
debug ppp neg
000124: *Jan 6 18:58:37.007 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
000125: *Jan 6 18:58:41.223 GMT: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
000126: *Jan 6 18:58:41.223 GMT: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
000127: *Jan 6 18:58:41.223 GMT: Vi2 PPP: Using dialer call direction
000128: *Jan 6 18:58:41.223 GMT: Vi2 PPP: Treating connection as a callout
000129: *Jan 6 18:58:41.223 GMT: Vi2 PPP: Phase is ESTABLISHING, Active Open
000130: *Jan 6 18:58:41.223 GMT: Vi2 PPP: No remote authentication for call-out
000131: *Jan 6 18:58:41.223 GMT: Vi2 LCP: O CONFREQ [Closed] id 32 len 14
000132: *Jan 6 18:58:41.223 GMT: Vi2 LCP: MRU 1478 (0x010405C6)
000133: *Jan 6 18:58:41.223 GMT: Vi2 LCP: MagicNumber 0x14FD518E (0x050614FD518E)
000134: *Jan 6 18:58:42.279 GMT: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
000135: *Jan 6 18:58:42.279 GMT: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
000136: *Jan 6 18:58:42.279 GMT: Vi2 PPP: Sending Acct Event[Down] id[11]
000137: *Jan 6 18:58:42.279 GMT: Vi2 LCP: State is Closed
000138: *Jan 6 18:58:42.279 GMT: Vi2 PPP: Phase is DOWN
000139: *Jan 6 18:58:43.295 GMT: %LINK-3-UPDOWN: Interface ATM0, changed state to down
000140: *Jan 6 18:58:44.295 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
Debug ATM Events
000245: *Jan 6 19:02:11.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000246: *Jan 6 19:02:12.115 GMT: atmsar_vc_tx_start(81C0A260).
000247: *Jan 6 19:02:12.115 GMT: ATM0:atmsar_dequeue_pak, dequeued a pak = 0x81
B19518
000248: *Jan 6 19:02:12.115 GMT: atmsar_transmit_pak_wrapper: deq(81B19518). vc
d: 1.atmsar_transmit_pak_wrapper : encap = Data
000252: *Jan 6 19:02:15.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000253: *Jan 6 19:02:16.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000254: *Jan 6 19:02:17.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000256: *Jan 6 19:02:18.955 GMT: ATM0: atmsar_atm_get_stats,vcinfo = 0x0
000257: *Jan 6 19:02:19.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000258: *Jan 6 19:02:20.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000259: *Jan 6 19:02:21.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000260: *Jan 6 19:02:22.131 GMT: atmsar_vc_tx_start(81C0A260).
000261: *Jan 6 19:02:22.131 GMT: ATM0:atmsar_dequeue_pak, dequeued a pak = 0x82
0A57BC
000262: *Jan 6 19:02:22.131 GMT: atmsar_transmit_pak_wrapper: deq(820A57BC). vc
000263: *Jan 6 19:02:22.143 GMT: ATM0: vcd = 1, safe_start called from periodic
000264: *Jan 6 19:02:23.143 GMT: ATM0: vcd = 1, safe_start called from periodic
Debug atm state
000306: *Jan 6 19:03:13.123 GMT: Changing vc 0/38vc-state to ATM_VC_SHUTTING_DOWN
000307: *Jan 6 19:03:13.123 GMT: Changing vc 0/38vc-state to ATM_VC_NOT_IN_SERVICE
debug dialer events
000327: *Jan 6 19:05:12.747 GMT: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
000328: *Jan 6 19:05:12.747 GMT: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
000329: *Jan 6 19:05:13.823 GMT: %LINK-3-UPDOWN: Interface ATM0, changed state to down
000330: *Jan 6 19:05:14.823 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
000331: *Jan 6 19:05:15.239 GMT: Di1 DDR: Cannot place call, no dialer string set
000332: *Jan 6 19:05:15.239 GMT: Di1 DDR: Cannot place call, no dialer string set
000333: *Jan 6 19:05:27.747 GMT: Vi2 DDR: re-enable timeout
Bronze
try and configure ´ip mtu 1452´ on your Dialer1 interface.
Also, configure the following on your Dialer1 interface:
ppp authentication chap pap callin
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password PASSWORD
If that doesn´t help, can you post the full configuration of your router ?
Nethelper
Attached is the whole config minus usernames and passwords. Any help much appreciated
266
