A few ubr7114E on one tv-cable
Can I assign a few ubr7114 to different frequency on one tv cable? The target is increase q-ty of CM on cable and scale up solution (as if, pay as needed).
1 ACCEPTED SOLUTION
Re: A few ubr7114E on one tv-cable
yes, it could be possible. The next problem how you assign cm to the new cmts. 72xx CMTS can bundle but the 7114 cant. The solution is, i think, to have diffrent docsis files for the new cmts, where you spec. the freq. in the docsisfile.
But you will still have noise problem om the HFC, so if i was you i would start making more segments in the HFC network to use multi US.
Martin
Denmark
1 REPLY
Martin
Denmark
118
