Webcast-Catalyst9k
able to ping PIX 501 but not SNMP
i'm able to ping the outside interface of our PIX 501 but i'm not able to get any SNMP stats. i'm sure the PIX is config-ed alittle too tightly.
i'm not the one who set it up so i'm don't know which command will loosen it up.
here is the config for reference:
PIX Version 6.3(1)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password yRWxZrM.WqHNW5QV encrypted
passwd 6xrNSBzsamLXqLkj encrypted
hostname KWCH-statefair
domain-name themeganet.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 102 permit ip 10.30.6.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list 102 permit ip 10.30.6.0 255.255.255.0 10.200.0.0 255.255.0.0
access-list 103 permit ip 10.30.6.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list 103 permit ip 10.30.6.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list 101 permit ip 10.30.6.0 255.255.255.0 10.30.40.0 255.255.248.0
access-list 101 permit ip 10.30.6.0 255.255.255.0 10.30.16.0 255.255.248.0
access-list 101 permit ip 10.30.6.0 255.255.255.0 10.30.24.0 255.255.248.0
access-list 101 permit ip 10.30.6.0 255.255.255.0 10.31.40.0 255.255.255.0
pager lines 24
logging on
logging monitor debugging
logging buffered debugging
mtu outside 1400
mtu inside 1500
ip address outside 68.99.115.199 255.255.255.224
ip address inside 10.30.6.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 103
nat (inside) 1 10.30.6.0 255.255.255.0 0 0
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 68.99.115.193 1
route outside 207.243.40.7 255.255.255.255 70.165.98.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.30.6.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community hiway
no snmp-server enable traps
no floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto map toRichmond 5 ipsec-isakmp
crypto map toRichmond 5 match address 101
crypto map toRichmond 5 set peer 64.148.165.242
crypto map toRichmond 5 set transform-set strong
crypto map toRichmond 10 ipsec-isakmp
crypto map toRichmond 10 match address 102
crypto map toRichmond 10 set peer 12.5.1.200
crypto map toRichmond 10 set transform-set strong
crypto map toRichmond interface outside
isakmp enable outside
isakmp key ******** address 12.5.1.200 netmask 255.255.255.255
isakmp key ******** address 64.148.165.242 netmask 255.255.255.255
isakmp identity address
isakmp keepalive 500 60
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 28800
telnet 64.148.165.242 255.255.255.255 outside
telnet 172.16.0.0 255.255.0.0 inside
telnet 10.30.6.0 255.255.255.0 inside
telnet 10.30.40.0 255.255.248.0 inside
telnet timeout 5
ssh 207.243.40.7 255.255.255.255 outside
ssh 66.136.242.129 255.255.255.255 outside
ssh 10.30.6.0 255.255.255.0 inside
ssh 10.200.24.0 255.255.248.0 inside
ssh 10.30.40.0 255.255.248.0 inside
ssh timeout 5
console timeout 0
dhcpd address 10.30.6.1-10.30.6.32 inside
dhcpd dns 10.30.47.4 10.30.47.7
dhcpd wins 10.30.47.4
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain kbsad.local
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:f0cc1b0a4205617b2b0bdb70b2a84c5a
1 ACCEPTED SOLUTION
Re: able to ping PIX 501 but not SNMP
You need to configure a location that is allowed to query SNMP. Here's an example-
snmp-server host inside 172.16.210.252 poll
This will allow the host 172.16.210.252 to access SNMP on the PIX.
Hope that helps.
the 172.16.210.252 is the source IP or the target?
Source IP. The host that will be querying the PIX.
okay, cool. i will give it a shot.
i put:
snmp-server host inside 10.30.41.60 poll
and it's still not working.
BUT i wasn't able to ping that 41.60 IP.
so i guess i'll need to open the PIX so that i can do that 1st.
do you rmemeber what the cmd is to let pings out the PIX?
998
