Silver
about PPPoE over Ethernet and LLQ
Hi folks,
I've to implement a PPPoE solution, with ppp authentication chap and LLQ for voice traffic. The client will be a 871, the RAS a 7200. I've no experience about vpdn/bba-group/etc... so any advice about the best way to follow will be appreciated :)
Andrea
Silver
Re: about PPPoE over Ethernet and LLQ
I think the LLQ cannot be applied on the LNS per session basis or at all.
Please refer to this link:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
and check the restrictions part.
In respect to the pppoe client (871) it is possible to configure it. See the bottom of the same link for configuration details.
Hope it helps, rate if does,
Krisztian
Silver
Thanks Krisztian,
a configuration like this, in your opinion, sounds correct?
PPPoE Client:
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
class-map match-any VoIP
match ip dscp ef
policy-map Dial0_Out-child
class VoIP-cm
priority 500
police 500000
class class-default
fair-queue
class class-default
shape average 5000000
service-policy Dial0_Out-child
interface Loopback0
ip address x.x.x.x 255.255.255.255
interface FastEthernet4
description *** WAN ***
no ip address
pppoe enable
pppoe-client dial-pool-number 1
service-policy output Dial0_Out
interface Vlan1
description *** LAN ***
ip address x.x.x.x 255.255.255.0
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname Test
ppp chap password
PPPoE RAS:
aaa authentication ppp default local
username Test password
vpdn enable
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 2
pppoe limit per-mac 10
pppoe limit max-sessions 32000
interface Loopback0
interface GigabitEthernet0/0.23
description ***Test PPPoE***
encapsulation dot1Q 23
pppoe enable
interface Virtual-Template2
mtu 1492
ip unnumbered Loopback0
no peer default ip address
Any advice will be appreciated
Thanks for your support
Andrea
Silver
Looks ok.
Please be careful with the shape average command. You always have to count with the overhead through SP network (pppoe overhead, ATM header). As I see it is only a test environment so it is not really problem. You also have to add route 0.0.0.0 0.0.0.0 dialer 0 on the client. The class-map match-any VoIP matches dscp ef so it assumes that your device is already set it. The nat setting is also missing.
On the concentrator if you use no peer default ip address under virtual-template you will have to assign somehow ip address for the peer (for example by means of radius).
Anyway it is ok.
Krisztian
Silver
Yes I know, my config is partial ...
So, just a question: what the difference between vpdn-group and bba-group?
thanks again for your support
Andrea
Silver
Honestly I don't know the exact difference between theses two as I haven't had to dig into this deeply but the below link explain what is the concept of pppoe profile (bba-group) and the difference between legacy mode (vpdn-group) and the other. I think the idea is similar to the ISDN where you can configure legacy and dialer profiles.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541b8.html
Krisztian
244
