Webcast-Catalyst9k
about WAN port on Cisco1812
Dear Sirs,
Does "WAN port" of Cisco1812 provide a special function?
Do you differ from Eternet port of usual ruters ?
Best regards,
1 REPLY
Silver
Re: about WAN port on Cisco1812
FastEthernet interface(FastEthernet0 or FastEthernet1) might randomly go down and back up in some situation.
This symptom occurs when you plug out and back in, or when you do a shut/no shut. or after a reload.
This symptom depends on the timing: Sometimes it cannot be seen in these situation above. Under the situation using RIP, it could be that flapping interface does not appear on RIP database and accordingly Cisco 1812 does not send rip update packets. About Wan and Ethernet Ports.Wan for Serial connection and Ehternet for Local Networks.
132
