Webcast-Catalyst9k
ACS 3.0 problem
hi everyone!
I have a problem in the ACS 3.0 running on win 2000. It seems that Network Access Restrictions (NAR) under group setup configuration doesn't display after i add and fill up the content and by clicking submit & restart. I did checked the box to enable the NAR but still won't working. ANd, im also using the shared-NAR and still same, won't work. But before i implemented, we have our own simulation lab here at our office & tested almost same configuration and still using same version and running on win 2000, it displays the content of the NAR
Do you think guys that there is a problem with there ACS server? or maybe some files are corrupted?
1 REPLY
Re: ACS 3.0 problem
To understand the problem better can you give me the follwing information.Is it working before?
Is this an initial configuration?What modifications made on the ACS? On the NAR?
116
