Community Member
ADSL over Routed bridge
Dear All
i am having a problem with an adsl connection when i try to use WIC-ADSL on 1841 router. The isp is using routed bridge encapsulation. with a static ip. i configured the the atm connection as follows
int atm0/0/0.1
pvc
8/35
atm routed-bridge ip
Created a static route to the gateway of the isp
i am able to ping the gateway but unable to ping any other website from the router nor from the users. can any one please help me with this problem
regards
aamir
Silver
Re: ADSL over Routed bridge
Community Member
just wanted to inform that i have already added the ip address (static) provided by the ISP. i want to use this atm connection to route internet traffice to the ethernet interface.
Community Member
Hi MUHAMMAD,
This seems to be an ISP issue since you can reach their network (gateway) but not further. Also, you can try configuring IRB as follows:
bridge irb
interface ATM0.1 point-to-point
bridge-group 1
pvc 0/35
encapsulation aal5snap
interface BVI1
ip address
ip route 0.0.0.0 0.0.0.0
bridge 1 protocol ieee
bridge 1 route ip
Let me know if it works!
Juan
173
