12-06-2006 03:11 PM
Does anyone know how to connect 2600 ADSL WIC to 2600 ADSL WIC without going through DSLAM? or this is not possible?
thanks
12-06-2006 10:44 PM
Hi Kang,
I dont think it is possible to connect ADSL WIC back-to-back due to the asymmetric nature and dual carrier nature (DSL + POTs) of ADSL. However, this can be done with SDSL.
Arul
** Please rate all helpful posts **
12-07-2006 08:09 AM
SDSL requires another hardware WIC? is that correct?
12-07-2006 11:20 AM
SDSL require other Hardware...
It is NOT possible to connect ADSL WICs back-to-back.
Thomas
12-07-2006 12:03 PM
Then, Can anyone tell me which device I can connect with ADSL WIC on the LAB environment?
12-08-2006 04:45 PM
You coud try an Adtran TotalAccess 1200 miniDSLAM. check out www.adtran.com
