Community Member
Allow VPN client to connect from the inside to another remote network
Hi, if I have a Cisco VPN client software on the inside of network and client is to connect to a remote network, over the internet. What ports need to be opened and on the outside interface/inside/both?
Thanks.
1 REPLY
Re: Allow VPN client to connect from the inside to another remot
Basically, all you need is UDP port 500, NAT-T will do the rest.
Connections are initiated from the inside and while everything is allowed in that direction, this should work by default.
If you have an access-list that limits traffic from inside to outside, you might need to allow this traffic.
Leo
291
