Analog Call through BRI
I am setting up an old router 3640 with mica modem and a BRI interface. I am trying to call from my PC through an analog line and connect to BRI, but I take the folllowing debug message:
Jun 1 10:44:35.329: ISDN BR0/0: Incoming call id = 0x0006, dsl 0
Jun 1 10:44:35.333: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x6 HOST_INCOMING_CALL
Jun 1 10:44:35.333: ISDN BR0/0: HOST_INCOMING_CALL: (non-POTS) VOICE
Jun 1 10:44:35.333: ISDN BR0/0: HOST_INCOMING_CALL: (1) call_type = VOICE
Jun 1 10:44:35.333: ISDN BR0/0: HOST_INCOMING_CALL: voice_answer_data = FALSE call type is VOICE ALAW
Jun 1 10:44:35.333: %CSM-1-HWREV: The T1 or E1 network module is incompatible with the digital modems: MODEM_REPORT
Jun 1 10:44:35.333: ISDN BR0/0: INCOMING CALL: VOICE ERROR: Requested circuit/channel not available(0x2C): bchan 0, call id 6
Jun 1 10:44:35.333: ISDN BR0/0: process_disconnect(): call id 0x6, call type is VOICE, b_idb 0x611BB53C, ces 1, cause Requested circuit/channel not available(0x2C)
Jun 1 10:44:35.337: ISDN: get_isdn_service_state(): idb 0x611BB53C bchan 2 is_isdn 1 Not a Pri
Jun 1 10:44:35.337: CCBRI_Go Fr Host InPkgInfo (Len=9) :
Jun 1 10:44:35.337: 7 0 1 0 6 3 18 1 89
Jun 1 10:44:35.337:
Jun 1 10:44:35.341: CCBRI_Go Fr Host InPkgInfo (Len=13) :
Jun 1 10:44:35.341: 5 0 1 0 6 3 8 1 AC 8 2 80 AC
Jun 1 10:44:35.341:
Jun 1 10:44:35.341: U99_DiscReq: CC_REL_CONF sent cid 0x6 cr 0xE1 ces 1 dsl 0
Jun 1 10:44:35.341: CCBRI_Go Fr L3 pkt (Len=4) :
Jun 1 10:44:35.341: 84 1 E1 99
Jun 1 10:44:35.341:
Jun 1 10:44:35.345: ISDN BR0/0: LIF_EVENT: ces/callid 1/0x6 HOST_DISCONNECT_ACK
Jun 1 10:44:35.345: ISDN: get_isdn_service_state(): idb 0x611BB53C bchan 2 is_isdn 1 Not a Pri
Jun 1 10:44:35.345: ISDN BR0/0: HOST_DISCONNECT_ACK: call type is VOICE
Jun 1 10:44:35.345: ISDN BR0/0: HOST_DISCONNECT_ACK: VOICE ERROR: Invalid CSM info(0xFB): bchan 0, call id 6
Jun 1 10:44:35.393: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0, TEI 70 changed to up
Jun 1 10:44:35.393: L3: L3_GetUser_NLCB returned NULL, message ignored cid 0x0 cr 0x0 ev 0x203 ces 1 dsl 0
Jun 1 10:44:35.669: TTY75: dropping DTR, hanging up
Jun 1 10:44:35.669: tty75: Modem: HANGUP->IDLE
Jun 1 10:44:40.685: TTY75: restoring DTR
Jun 1 10:44:41.685: TTY75: autoconfigure probe started
Jun 1 10:44:50.357: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0, TEI 70 changed to down
Can i do that or I must use a PRI interface? Is there any way to terminate analalog calls to BRI interface?
Thanks in advance!
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Analog Call through BRI
Which module do you have ? Include "show diag".
Finally I found out the restrictions for the Cisco 3640 router in the following link:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t3/feature/guide/3600mbri.html
I must use different network module and not a WIC or VIC BRI interface.
This is your relevant document, now 11 years old:
http://www.cisco.com/en/US/ts/fn/000/fn2128_12011998.html
291
