Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Another VPN access problem
I am new to the whole Cisco stuff but basically I've got everything setup to how I need EXCEPT VPN. I can connect and pull an IP from the correct pull, but cannot access anything on the lan. I am trying to hit host 192.168.123.123. I am using group Lasttry for the VPN connection (192.168.31.0/24).
Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
passwd DcV4kd8yeNeI78yV encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport trunk native vlan 1
interface Ethernet0/3
switchport access vlan 114
interface Ethernet0/4
interface Ethernet0/5
switchport trunk allowed vlan 1,101-104
switchport mode trunk
interface Ethernet0/6
switchport access vlan 104
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.195.2 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan101
nameif VOIP
security-level 50
ip address 172.16.1.1 255.255.255.0
interface Vlan102
nameif guest
security-level 50
ip address 172.16.2.1 255.255.255.0
interface Vlan104
nameif SEC-SYSTEM
security-level 50
ip address 172.16.4.1 255.255.255.0
interface Vlan114
nameif itwatchdog
security-level 50
ip address 192.168.123.1 255.255.255.0
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
object-group service HTTP
service-object tcp source eq www
object-group network Webserver
network-object host 192.168.195.10
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service SecureSHELL7250
description SecureSHELL7250
service-object tcp eq 7250
access-list inside_nat0_outbound extended permit ip any 192.168.4.0 255.255.255.224
access-list inside_nat0_outbound extended permit ip 192.168.4.0 255.255.255.224 interface inside
access-list inside_nat0_outbound extended permit ip any 192.168.30.0 255.255.255.192
access-list inside_nat0_outbound extended permit ip 192.168.30.0 255.255.255.192 interface inside
access-list inside_nat0_outbound extended permit ip 192.168.123.0 255.255.255.0 192.168.31.0 255.255.255.240
access-list inside_nat0_outbound extended permit ip any 192.168.31.0 255.255.255.0
access-list guest_access_in extended permit ip any any
access-list outbound extended permit gre any any
access-list outbound extended permit tcp any any eq pptp
access-list outbound extended permit ip any any
access-list outbound extended permit tcp any any eq smtp
access-list SEC-SYSTEM_access_in extended permit ip any any
access-list VOIP_access_in extended permit ip any any
access-list itwatchdog_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any interface outside eq www
access-list outside_access_in extended permit tcp any interface outside eq 7250
access-list Lasttry_splitTunnelAcl standard permit 192.168.123.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu guest 1500
mtu VOIP 1500
mtu SEC-SYSTEM 1500
mtu itwatchdog 1500
ip local pool TestVPN 192.168.4.1-192.168.4.20 mask 255.255.255.0
ip local pool WLGroup 192.168.30.1-192.168.30.50 mask 255.255.255.0
ip local pool LasttryPool 192.168.31.5-192.168.31.10 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (inside) 2 interface
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (guest) 1 0.0.0.0 0.0.0.0
nat (VOIP) 1 0.0.0.0 0.0.0.0
nat (SEC-SYSTEM) 1 0.0.0.0 0.0.0.0
nat (itwatchdog) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface www 192.168.195.10 www netmask 255.255.255.255 tcp 100 50
static (inside,outside) tcp interface 7250 192.168.195.10 7250 netmask 255.255.255.255
static (VOIP,inside) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
static (itwatchdog,inside) 192.168.123.0 192.168.123.0 netmask 255.255.255.0
static (inside,VOIP) 192.168.195.0 192.168.195.0 netmask 255.255.255.0
static (inside,itwatchdog) 192.168.195.0 192.168.195.0 netmask 255.255.255.0
access-group outbound in interface inside
access-group outside_access_in in interface outside
access-group guest_access_in in interface guest
access-group VOIP_access_in in interface VOIP
access-group SEC-SYSTEM_access_in in interface SEC-SYSTEM
access-group itwatchdog_access_in in interface itwatchdog
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.195.0 255.255.255.0 inside
http 192.168.4.0 255.255.255.0 inside
http 192.168.4.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.195.0 255.255.255.0 inside
telnet 172.16.1.0 255.255.255.0 guest
telnet timeout 5
ssh 192.168.195.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 45
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.195.221-192.168.195.249 inside
dhcpd enable inside
dhcpd address 172.16.2.11-172.16.2.200 guest
dhcpd enable guest
dhcpd address 172.16.1.20-172.16.1.50 VOIP
dhcpd enable VOIP
dhcpd address 172.16.4.155-172.16.4.175 SEC-SYSTEM
dhcpd enable SEC-SYSTEM
dhcpd address 192.168.123.124-192.168.123.128 itwatchdog
dhcpd enable itwatchdog
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy TestVPN internal
group-policy TestVPN attributes
dns-server value 192.168.195.2
vpn-filter value inside_nat0_outbound
vpn-tunnel-protocol IPSec
group-policy GroupPolicy1 internal
group-policy WLGROUP internal
group-policy WLGROUP attributes
group-policy Lasttry internal
group-policy Lasttry attributes
dns-server value 8.8.8.8
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Lasttry_splitTunnelAcl
username sshadmin password fftiVkbaHCU3ZSQW encrypted privilege 15
username john password zRKfQe22pw2SxU1g encrypted privilege 0
username john attributes
vpn-group-policy TestVPN
tunnel-group TestVPN type remote-access
tunnel-group TestVPN general-attributes
address-pool TestVPN
default-group-policy TestVPN
tunnel-group TestVPN ipsec-attributes
pre-shared-key *****
tunnel-group WLGROUP type remote-access
tunnel-group WLGROUP general-attributes
address-pool WLGroup
default-group-policy WLGROUP
tunnel-group WLGROUP ipsec-attributes
tunnel-group Lasttry type remote-access
tunnel-group Lasttry general-attributes
address-pool LasttryPool
default-group-policy Lasttry
tunnel-group Lasttry ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect pptp
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
: end
Hall of Fame Super Silver
John
I have looked through the information that you posted and am not clear about the topology of the network. I see two ports on the ASA that are in vlan 114 which is the vlan for the host you are attempting to access through the vpn connection. Is this host connected to one of these ports? Or is it somewhere else in your network? If it is somewhere else in the network can you check whether it has a valid route to network 192.168.31.0?
Rick
remove
then then check....
also
remove
add
access-list inside_nat0_outbound extended permit ip 192.168.123.0 255.255.255.0 192.168.31.0 255.255.255.0
Jawad
Jawad
Silver
Hall of Fame Super Gold
Wrong forum, post in "Security - VPN". You can move your posting with the Actions panel on the right.
i have a similiar problem. if there is a resolution to this please let me know.
kevin
Please try to add the crypto isakmp nat-traversal 30, try to connect again and test the results. If this does not work we can follow some TS steps
my appologies for not seeing your post until now. my config is slightly different. i am missing what you are suggesting to try.
i will add it in later tonight and post back. below is my current configuration for pix 525. what troubleshooting steps should be taken if that doesn't work?
show config
: Saved
: Written by enable_15 at 06:25:46.787 UTC Fri Oct 18 2013
PIX Version 8.0(4)
hostname thcvpn01
domain-name somewhere.net
enable password * encrypted
passwd * encrypted
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.1.1 255.0.0.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 208.67.222.222
name-server 208.67.222.220
object-group icmp-type ICMPObject
icmp-object echo-reply
icmp-object source-quench
icmp-object time-exceeded
icmp-object unreachable
access-list outside_access_in extended permit icmp any any object-group ICMPObject
pager lines 24
mtu outside 1500
mtu inside 1500
ip local pool ThcIPPool 10.1.1.40-10.1.1.49
no failover
arp timeout 14400
nat-control
global (outside) 101 interface
nat (inside) 101 10.0.0.0 255.0.0.0
http server enable
http 10.0.0.0 255.0.0.0 inside
crypto ipsec transform-set THCTransformSet esp-3des esp-md5-hmac
crypto dynamic-map THCDynamicMap 1 set transform-set THCTransformSet
crypto dynamic-map THCDynamicMap 1 set security-association lifetime seconds 288
00
crypto dynamic-map THCDynamicMap 1 set security-association lifetime kilobytes 4
608000
crypto dynamic-map THCDynamicMap 1 set reverse-route
crypto map THCCryptoMap 1 ipsec-isakmp dynamic THCDynamicMap
crypto map THCCryptoMap interface outside
encryption 3des
hash sha
group 2
lifetime 43200
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
username [username] password [password] encrypted
tunnel-group THCVpnGroup type remote-access
tunnel-group THCVpnGroup general-attributes
address-pool ThcIPPool
tunnel-group THCVpnGroup ipsec-attributes
pre-shared-key *
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
Cryptochecksum:0be52458c95d5dd080d82401982201ee
thcvpn01(config-pmap-c)#
1453
