AS5300 in POS environment
We have a AS5300 loaded with MICA modems and 4xT1 card. POS terminals dialup to the AS5300 and fork a telnet stream to a host target HOST_A on a specific port. Here is a snippet of how my lines are configured
ip host HOST_A 1075 192.168.1.2
modemcap entry POS_TERMINAL:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S52=0S53=0S54=32968S64=10
line 1 48
no motd-banner
no exec-banner
exec-timeout 0 0
no flush-at-activation
no vacant-message
modem InOut
modem autoconfigure type POS_TERMINAL
autocommand telnet HOST_A /stream /noecho /quiet
no activation-character
transport input all
transport output all
escape-character NONE
dispatch-timeout 1500
My problem is that the AS5300 sends several extra DEL (Delete) characters which cause the POS terminal to reject transactions. Below is the output of a capture from a RS232 protocol analyzer
Data received: <CR><LF>OK<CR><LF>
Data received: <CR><LF>CONNECT<Space>38400/NONE/1200<CR><LF><Delete>
Data received: <Delete>
Data received: <Delete>|
Data received: <ENQ><NUL>
Data received: <STX>XXXXXXXXXX<FS>0000090<FS>0000036<FS>001<FS>82
Data received: 5<Space><Space><Space><Space><Space><Space><Space><Space><Space>$0.36<FS>0000<ETX>@
Data received: <EOT><NUL>
Data received: <FF>c?
I believe these delete characters are part of the telnet protocol specs, but I could be wrong, because the "stream" option should send the data in a raw tcp stream. Anybody have any ideas on how to remove the extra DEL characters from the stream or maybe there is another way to do this without using the "modem autoconfigure" option.
Matteo D'Amato
Manager, Systems Applications & Development
Smartbox Equipment Inc
Silver
Re: AS5300 in POS environment
Matteo,
I know you've asked this question before, here and on comp.dcom.sys.cisco. Below your post you can see an "ASK THE EXPERT" thread where an expert from cisco is answering questions about AS5X00 problems. I suggest you post your question there.
I tried Zulfiqar's suggestion in "ASK THE EXPERT" to test if my host was in telnet mode by trying:
telnet HOST_A /debug
and I can confirm that HOST_A is not in telnet mode. Other people have suggested shortening my modem INIT string. When I set it to:
POS_TERMINAL:MSC=&F&D2S0=0S29=4S21=0S22=0S23=0S24=0
I do see fewer delete characters sent. This was the only change that actually had an effect on the delete characters. Does anyone have other suggestions. Thanks
With the above modem INIT string the deletes seem to be part of the connect message sent by the MICA modems.
Data received: CONNECT38400/NONE/2400
Data received:
Data received: ********00002200003122001857122$31.220000Q
Data received:
Data received: F??wwwwwww
Data received: NOCARRIER
Is there a way to set the modems in quite mode so that it doesn't send the connect message? Maybe this will remove the extra delete characters.
Matteo D'Amato
188
