10-03-2006 07:12 AM
Hi. Actually I've been working with a AS5300 with 120 lines. The AS reports six lines with problems. When I cheked its status, I see this messages ( With SH LINE command ):
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 2/36 Digital modem - DialIn - - - 0 0 0/0 -
* 2/37 Digital modem - DialIn - - - 0 0 0/0 -
* 2/38 Digital modem - DialIn - - - 0 0 0/0 -
* 2/39 Digital modem - DialIn - - - 0 0 0/0 -
* 2/40 Digital modem - DialIn - - - 0 0 0/0 -
* 2/41 Digital modem - DialIn
If you see the use's column, it is in cero. Of cuourse, those modems has problems. I wrote "clear line" command and the problem is. I shutdown the AS too, but the problem continues. Anybody knows what kind of problem is this? Anybody can help me?
Thanks a lot.
Francisco Velasco
10-04-2006 10:19 PM
Hola Franscisco,
what modems are you using ? Can you post the output of:
show modem version
show modem mapping
show version
GNT
10-05-2006 06:34 AM
Hi Sr. First at all I appreciate a lot your help. This is the output of the "show modemcap" and "show version" commands, because our AS doesn't support your commands.
Switch# show modemcap
default
codex_3260
usr_courier
usr_sportster
hayes_optima
global_village
viva
telebit_t3000
microcom_hdms
microcom_server
nec_v34
nec_v110
nec_piafs
cisco_v110
microcom_mimic
mica
nextport
scm
Switch# sh version
IOS (tm) 5350 Software (C5350-IS-M), Version 12.3(3g), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 21-May-04 02:46 by kellythw
Image text-base: 0x6000895C, data-base: 0x61600000
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
BOOTLDR: 5350 Software (C5350-BOOT-M), Version 12.2(2)XB2, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
accserver5 uptime is 1 week, 1 hour, 14 minutes
System image file is "flash:c5350-is-mz.123-3g.bin"
cisco AS5350 (R7K) processor (revision T) with 262144K/131072K bytes of memory.
Processor board ID JAE0822JW8B
R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x32,
Board Hardware Version 3.34, Item Number 800-5171-02,
Board Revision C0, Serial Number JAE0822JW8B,
PLD/ISP Version 2.2, Manufacture Date 26-May-2004.
Processor 0x14, MAC Address 0x0FF7D047B2
Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet/IEEE 802.3 interface(s)
130 Serial network interface(s)
120 terminal line(s)
4 Channelized E1/PRI port(s)
512K bytes of non-volatile configuration memory.
65536K bytes of processor board System flash (Read/Write)
16384K bytes of processor board Boot flash (Read/Write)
Thanks again and I'll waut your answer.
Reggards,
Francisco Velasco
