AS5300 PRIs - 24th call failing
I have an AS5300 with 4 PRIs terminated into it configured with NFAS. The other end of these PRI is to a MetaSwitch. Dial-up users through the MetaSwitch down the PRIs are working fine untill all B-channels are full on the primary PRI. The next call (24th) gets a busy. I have disconnected the primary PRI and had the users come down the 2nd PRI and the problem follows. So the PRIs are operational, I just can't get that 24th call to roll to the next PRI. Debug as follows on the 24th call:
Feb 13 18:51:11: ISDN Se1:23: RX <- SETUP pd = 8 callref = 0x6701
Feb 13 18:51:11: Bearer Capability i = 0x8090A2
Feb 13 18:51:11: Channel ID i = 0xE9878301
Feb 13 18:51:11: Progress Ind i = 0x8481 - Call not end-to-end ISDN, may have in-band info
Feb 13 18:51:11: Called Party Number i = 0xC1, 'XXXXXXX', Plan:ISDN, Type:Subscriber(local)
Feb 13 18:51:11: Original Called Number i = 0x21000F81, 'XXXXXXXXXX'
Feb 13 18:51:11: ISDN Se1:23: TX -> RELEASE_COMP pd = 8 callref = 0xE701
Feb 13 18:51:11: Cause i = 0x80E418 - Invalid information element contents
Hall of Fame Super Gold
Re: AS5300 PRIs - 24th call failing
Hi, what is the nfas config you have on the as5300 ? And how many d-channels you have ?
For example, if you have only one D-channel on the primary pri, bringing it down should make impossible to call, as there is no d-chan anymore.
In this sense it can be easier to just forget about nfas and just run regular pri over all circuits.
I have a primary and secondary D channel that are functioning as expecting. I can bring the primary NFAS D channel down and the second takes over. No D channels on PRI 3 and 4 they are using pri and sec of PRI 1 and 2.
Can you post nfas-relevant config for the 5300.
I haven't decoded the nfas channel id, but that's a track.
controller T1 0
framing esf
clock source line primary
linecode b8zs
cablelength short 133
pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 2
controller T1 1
framing esf
clock source line secondary 1
linecode b8zs
pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 2
controller T1 2
framing esf
clock source line secondary 2
linecode b8zs
pri-group timeslots 1-24 nfas_d none nfas_int 2 nfas_group 2
controller T1 3
framing esf
clock source line secondary 3
linecode b8zs
pri-group timeslots 1-24 nfas_d none nfas_int 3 nfas_group 2
So i only have ser0:23 configured and all other D channels inherit the 0:23 config. Do I need a dialer int to tie all the PRIs together?
Yes, the interfaces should all go into the same dialer pool and the dialer has all the config.
Here is the dialer i configured. i applied this to ser0:23 as follows
interface Dialer1
ip unnumbered FastEthernet0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer idle-timeout 3600
dialer-group 1
peer default ip address pool AS5300-1
no fair-queue
no cdp enable
ppp authentication pap callin
ppp multilink
interface Serial0:23
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn switch-type primary-dms100
isdn incoming-voice modem
no fair-queue
no cdp enable
Hmm I think under dialer you need dialer pool 1 and under serial you need dialer pool-member, no need for dialer-group.
Thanks for all the assistance. I will try that.
380
