Community Member
AS5300 with IDSN PRI for VoIP and 56K dialup
Hello everyone, I'm faced with a configuration issue on an existing AS5300 server
[IOS (tm) 5300 Software (C5300-JS-M), Version 12.3(15)]
24 Serial network interface(s)
60 terminal line(s)
4 Channelized T1/PRI port(s)
30 DSP(s), 30 Voice resource(s)
I have been able to route any voice calls to SBC's via session targets and dialp-peers although I cannot make 56K dialup calls to async ports. Modems are all running:
Modem module Firmware Boot DSP
Mdm Number Rev Rev Rev
1/0 0 2.9.5.0
and modem tests show all are functioning. I can make outbound calls using isdn test calls to any number, so I know two 2way PRI is working correctly on that regard.
Is there anything else that I can look at or do I have some mistakes in my config:
controller T1 0
framing esf
clock source line primary
linecode b8zs
pri-group timeslots 1-24
interface Serial0:23
ip unnumbered Ethernet0
encapsulation ppp
dialer-group 1
isdn switch-type primary-ni
isdn incoming-voice modem
peer default ip address pool setup_pool
ppp authentication chap pap
interface Group-Async1
ip unnumbered FastEthernet0
encapsulation ppp
ip tcp header-compression
timeout absolute 1440 0
async mode interactive
ppp authentication pap callin
group-range 1 60
line 1 60
login local
modem InOut
modem autoconfigure discovery
modem dialout controller 0
transport input all
autoselect during-login
autoselect ppp
I have tried many diffenent combinations of the above but can somebody suggest anything else?
thanks
some extra info
AS5300#show modem map
Slot 1 has Mica Carrier card.
Modem Firmware Firmware
Module Numbers Rev Filename
0 1/0 - 1/5 2.9.5.0 IOS-Default
1 1/6 - 1/11 2.9.5.0 IOS-Default
2 1/12 - 1/17 2.9.5.0 IOS-Default
3 1/18 - 1/23 2.9.5.0 IOS-Default
4 1/24 - 1/29 2.9.5.0 IOS-Default
5 1/30 - 1/35 2.9.5.0 flash:mica-modem-pw.2.9.5.0.bin
6 1/36 - 1/41 2.9.5.0 flash:mica-modem-pw.2.9.5.0.bin
7 1/42 - 1/47 2.9.5.0 flash:mica-modem-pw.2.9.5.0.bin
8 1/48 - 1/53 2.9.5.0 flash:mica-modem-pw.2.9.5.0.bin
9 1/54 - 1/59 2.9.5.0 flash:mica-modem-pw.2.9.5.0.bin
Firmware-file Version Firmware-Type
system:/ucode/mica_board_firmware 3.0.4.1 Mica Boardware
system:/ucode/mica_port_firmware 2.9.5.0 Mica Portware
system:/ucode/microcom_firmware 5.2.30 Microcom F/W and DSP
flash:mica-modem-pw.2.9.5.0.bin 2.9.5.0 Mica Portware
AS5300#
1 ACCEPTED SOLUTION
Re: AS5300 with IDSN PRI for VoIP and 56K dialup
As far as I know, you are not able to use VoIP and H323 simultaneously on the 5300. You can on the 5350, though.
Community Member
Thanks for the info, however going backwards I am not able to configure the AS5300 as a dedicated Dial-up access server for ISP customers to dial-up to 56K
Perhaps the modem software is out of date on my router?
Do you mean that your customers are not able to establish V.90 56Kbps dial-up sessions, but V.34 and V.34+ works??
Community Member
Hi, yes that is correct. I have never been able to dial up at 56K to our server, and am not sure where to start looking for a solution
417
