Community Member
AS5350 Dial-up woes --solved disregard
My AS5350 stopped allowing calls to connect. They handshake for 30-45 seconds and then disconnect. My experience with these is pretty limited since we only still have a few using dial-up instead of VPN. Any ideas?
Here's some debug output.
Mar 19 15:23:31.591: //NP DSPLIB/np_dsplib_process_statechange:
(1/56):Modem state change to TERMINATING_STATE
Mar 19 15:23:31.591: //NP DSPLIB/np_dsplib_notify_csm_onhook:
(1/56):Modem went onhook
Mar 19 15:23:31.591: //CSM/csm_proc_ic7_oc6_connected:
v(1/56):[CSM_IC7_CONNECTED:CSM_EVENT_MODEM_ONHOOK]
Mar 19 15:23:31.591: msg_to_calls_mgmt: msg type CPM_CSM_DISC_CALL received
Mar 19 15:23:31.591: RPA CAS Resource(1/56) DS0(0:3:0:22) State:RPM_RES_ALLOCATED Event:RPA_CAS_DISCONNECT
Mar 19 15:23:31.591: //CSM/csm_send_neat_cas_event:
CSM->NEAT [0xEC8]EVENT_CALL_IDLE SUCCESS for c(3/0:22) v(1/56) rc=0
--More--
Mar 19 15:23:31.591: //CSM/csm_enter_disconnecting_state:
v(1/56)
Mar 19 15:23:31.595: csm_call_prog_disc_reason - DATA
Mar 19 15:23:31.595: tty=0x64D98520 num=272 port=56 slot=1 shelf=0 type=2 name=1/56 idb=0x64D97450
Mar 19 15:23:31.595: msg_to_calls_mgmt: msg type CPM_VOICE_CALL_MOD_REJ received
Mar 19 15:23:32.463: //NP DSPLIB/np_dsplib_notify_csm_onhook:
Mar 19 15:23:32.463: //CSM/csm_proc_ic8_oc8_disconnecting:
v(1/56):[CSM_IC8_DISCONNECTING:CSM_EVENT_MODEM_ONHOOK]
Mar 19 15:23:32.463: //NP DSPLIB/np_dsplib_call_hangup:
(1/56):reason=14 Fax=FALSE
Mar 19 15:23:32.463: //CSM/csm_enter_idle_state:
v(1/56)
modem related. problem solved.
193
