Community Member
ASA 5505 vpn/OWA issue
I have a client that is running Win2003 Server R2 with Exchange Server 2003. OWA was setup and clients could connect to their exchange mailbox from the internet with no problems.
We recently configured vpn on the ASA 5505 and now no-one can connect to OWA since that time.
Any thoughts?
Re: ASA 5505 vpn/OWA issue
Have you been using the ASDM to configure the VPN? In that case, you may have removed the required portforwarding or modified the access-list that allows traffic from the outside.
regards,
Leo
Community Member
Yes we did use the ASDM to setup and configure the vpn. What do I need to do to put the port forwarding back. Bit of a novice with the cisco stuff.
Please post your configuration so that we can have a look at it. The problem is clear, a look at the config will be needed to determine the cause.
regards,
Leo
Community Member
Here is our current configuration...some stuff is x'd out to protect the innocent.
Thanks for your help
237
