ASA 5510 Problem
Hi, I have an issue--basically all of the tunnels terminating on a 2811 router are up/down. They were up earlier today, but we made some changes on teh ASA, tried to revert but cannot seem to find the problem. Posted below is the configuration...
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Remote_Site_A
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Remote_Site_B
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Remote_Site_C
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Remote_Site_D
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Remote_Site_E
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Remote_Site_F
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.0.0.0 192.168.43.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.0.0.0 192.168.44.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 10.233.59.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Loop_A
access-list inside_nat0_outbound extended permit ip host MAIN_SWITCH host Loop_B
access-list Security-PA2 extended permit ip host MAIN_SWITCH host Remote_Site_B
access-list Security-PA3 extended permit gre host MAIN_SWITCH host Remote_Site_A
access-list Security-NJ extended permit gre host MAIN_SWITCH host Remote_Site_C
access-list Security-PA extended permit ip host MAIN_SWITCH host Loop_B
access-list Split_Tunnel_Acl standard permit 10.0.0.0 255.0.0.0
access-list Split_Tunnel_Acl standard permit 192.168.128.0 255.255.255.0
access-list Split_Tunnel_Acl standard permit 192.168.160.0 255.255.255.0
access-list Split_Tunnel_Acl standard permit 192.168.144.0 255.255.255.0
access-list Split_Tunnel_Acl standard permit 192.168.130.0 255.255.255.0
access-list Split_Tunnel_Acl standard permit 192.168.140.0 255.255.255.0
access-list Security-USA extended permit gre host MAIN_SWITCH host Remote_Site_D
access-list ISA-Server extended permit object-group tcpudp host 192.168.44.190 object-group DC_Server_Group object-group DNS_tcp-udp
access-list ISA-Server extended permit object-group tcpudp host 192.168.44.190 object-group DC_Server_Group object-group Kerberos
access-list ISA-Server extended permit tcp host 192.168.44.190 host Exchange_Server eq https
access-list ISA-Server extended permit object-group tcpudp host 192.168.44.190 object-group DC_Server_Group eq 389
access-list ISA-Server extended permit tcp host 192.168.44.190 host 10.233.43.85 eq https
access-list ISA-Server extended permit tcp any any eq https
access-list ISA-Server extended permit icmp any any
access-list ISA-Server extended permit tcp host 192.168.44.190 object-group PatchLink-Servers eq www
access-list ISA-Server extended permit tcp host 192.168.44.190 host touchpointdemo eq www
access-list ISA-Server extended permit tcp host 192.168.44.190 host touchpointdemo2 eq www
access-list extdmz-in extended permit tcp host 192.168.43.189 object-group ALL-SMTP-Servers eq smtp
access-list extdmz-in extended permit tcp host 192.168.43.189 object-group OUTSIDE-CONTRACTOR eq smtp
access-list extdmz-in extended permit tcp host 192.168.33.27 object-group Wyeth_SMTP eq smtp
access-list extdmz-in extended permit tcp host 192.168.43.190 any eq www
access-list extdmz-in extended permit tcp host 192.168.43.189 any eq domain
access-list extdmz-in extended permit tcp host 192.168.43.190 any eq domain
access-list extdmz-in extended permit udp host 192.168.43.189 any eq domain
access-list extdmz-in extended permit udp host 192.168.43.190 any eq domain
access-list extdmz-in extended permit tcp host 192.168.43.189 any eq https
access-list extdmz-in extended permit tcp host 192.168.43.189 any eq ftp
access-list extdmz-in extended permit tcp host 192.168.43.190 any eq ftp
access-list extdmz-in extended permit tcp host 192.168.43.190 any eq https
access-list Security-Calif extended permit gre host MAIN_SWITCH host Remote_Site_F
access-list outside-in extended permit tcp any host ISA_Server_Ext eq https
access-list outside-in extended permit icmp any any object-group ping
access-list outside-in extended permit tcp object-group MSG_LAB host Ext_SMTP_Ext eq smtp
access-list outside-in extended permit tcp object-group MessageLabs_SMTP host Ext_SMTP_Ext eq smtp
access-list outside-in extended permit tcp object-group OUTSIDE-CONTRACTOR host Ext_SMTP_Ext eq smtp
access-list outside-in extended permit tcp any host ISA_Server_Ext eq www
access-list outside-in extended permit udp object-group iNet_Hdw host 10.233.43.251 eq tftp
access-list inside-in extended permit tcp any object-group ExtDMZ-Servers object-group RemoteManagement
access-list inside-in extended permit tcp any host 192.168.44.190 object-group RemoteManagement
access-list inside-in extended permit tcp any object-group ExtDMZ-Servers eq www
access-list inside-in extended permit tcp host Exchange_Server host ISA-Server_Inside eq https
access-list inside-in extended permit tcp object-group Internal_SMTP host Ext_SMTP eq smtp
access-list NJ-VPN extended permit ip host MAIN_SWITCH host Loop_A
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256_ESP-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5-DH7 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA ESP-AES-256_ESP-SHA
crypto map outside_map 20 match address Security-PA3
crypto map outside_map 20 set peer y.y.y.y
crypto map outside_map 20 set transform-set ESP-AES-256-SHA
crypto map outside_map 30 match address Security-PA2
crypto map outside_map 30 set peer x.x.x.x
crypto map outside_map 30 set transform-set ESP-AES-256-SHA
crypto map outside_map 40 match address Security-NJ
crypto map outside_map 40 set peer x.x.x.x
crypto map outside_map 40 set transform-set ESP-AES-256-SHA
crypto map outside_map 45 set peer y.y.y.y
crypto map outside_map 45 set transform-set ESP-AES-256_ESP-SHA
crypto map outside_map 50 set peer x,x,x,x
crypto map outside_map 50 set transform-set ESP-AES-256-SHA
crypto map outside_map 60 match address Security-USA
crypto map outside_map 60 set peer x,x,xx
crypto map outside_map 60 set transform-set ESP-AES-256-SHA
crypto map outside_map 70 match address Security-Calif
crypto map outside_map 70 set peer x.x.x.x
crypto map outside_map 70 set transform-set ESP-AES-256_ESP-SHA
crypto map outside_map 71 match address Security-Calif
crypto map outside_map 71 set peer x.x.x.x
crypto map outside_map 71 set transform-set ESP-AES-256_ESP-SHA
crypto map outside_map 80 match address NJ-VPN
crypto map outside_map 80 set peer x.x.x.x
crypto map outside_map 80 set transform-set ESP-AES-256_ESP-SHA
crypto map outside_map 90 set peer x.x.x.x
crypto map outside_map 90 set transform-set ESP-AES-256_ESP-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp identity address
isakmp enable outside
isakmp policy 4 authentication pre-share
isakmp policy 4 encryption 3des
isakmp policy 4 hash md5
isakmp policy 4 group 7
isakmp policy 4 lifetime 86400
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes-256
isakmp policy 10 hash sha
isakmp policy 10 group 5
isakmp policy 10 lifetime 86400
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption 3des
isakmp policy 30 hash sha
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption 3des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
isakmp nat-traversal  20
tunnel-group DefaultRAGroup ipsec-attributes
isakmp keepalive threshold 10
pre-shared-key *
tunnel-group a.b.d.h type ipsec-l2l
tunnel-group a.b.d.h ipsec-attributes
pre-shared-key *
tunnel-group VPN type ipsec-ra
tunnel-group VPN general-attributes
address-pool pool1
authentication-server-group radius
default-group-policy VPN
strip-realm
tunnel-group VPN ipsec-attributes
pre-shared-key *
radius-with-expiry
tunnel-group a.b.c.d type ipsec-l2l
tunnel-group a.b.c.d ipsec-attributes
pre-shared-key *
Here are the errors:
On the 2811 router, which terminates the tunnel (since the ASA is version 7 and doesnt run EIGRP:
1#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/1            10.x.t.100    YES NVRAM  up                    up
Loopback1                  10.x.t.197    YES NVRAM  up                    up
Tunnel11                   10.x.t.149    YES NVRAM  up                    down
Tunnel12                   10.x.t.157    YES NVRAM  up                    down
Tunnel13                   10.x.t.165    YES NVRAM  up                    down
Tunnel15                   10.x.t.233    YES NVRAM  up                    down
Tunnel16                   10.x.t.245    YES NVRAM  up                    down
Tunnel17                   10.x.t.117    YES NVRAM  up                    down
Tunnel19                   10.x.t.146    YES NVRAM  up                    down
And on the ASA:
[IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0x35b7bb4c)!
Oct 08 21:36:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
asa# Oct 08 21:37:18 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0xbfdc6fd1)!
Oct 08 21:37:18 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
Oct 08 21:37:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0xa61c06a9)!
Oct 08 21:37:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
Oct 08 21:38:18 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0x35dc0cd4)!
Oct 08 21:38:18 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
asa# Oct 08 21:38:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0x448cd5f8)!
Oct 08 21:38:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
Oct 08 21:39:18 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0xe6c95f0f)!
Oct 08 21:39:18 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
asa#
asa#
asa# show run | iOct 08 21:39:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, QM FSM error (P2 struct &0x3e747d0, mess id 0x245ada99)!
Oct 08 21:39:48 [IKEv1]: Group = a.b.c.d, IP = a.b.c.d, Removing peer from correlator table failed, no match!
Please assist!
Ive tried for hours but I think the problem is phase 2 and the crypto map....all spokes are down.
  • Remote Access
Re: ASA 5510 Problem
I assume that you are running GRE tunnel on the 2811 behind the ASA, and ASA is establishing the IPSec tunnel.
I didn't see access-group command posted earlier, however, i assume that your 2811 router is connected to your ASA inside interface, and acl assigned is named "inside-in". I did not see ACL line that permits GRE that would allow the traffic through the ASA.
hi, yes, your assumptions are right--the 2811 is terminating gre tunnel--via eigrp.
Is this what i need to add?
access-list inside-in extended permit gre any any
i added it--to no avail:
also, i have:
# show run | in access-group
access-group outside-in in interface outside
access-group extdmz-in in interface extdmz
access-group isadmz-in in interface isadmz
at one of teh spoke offices:
000624: *Oct  9 00:39:02.471 GMT: ISAKMP:(2365):purging node 904887933
000625: *Oct  9 00:39:09.351 GMT: ISAKMP: DPD received KMI message.
000626: *Oct  9 00:39:09.351 GMT: ISAKMP: set new node 353388376 to QM_IDLE
000627: *Oct  9 00:39:09.351 GMT: crypto_engine: Generate IKE hash
000628: *Oct  9 00:39:09.351 GMT: CryptoEngine0: CRYPTO_ISA_IKE_HMAC(hw)(ipsec)
000629: *Oct  9 00:39:09.355 GMT: ISAKMP:(2768):Sending NOTIFY DPD/R_U_THERE protocol 1
        spi 1706225560, message ID = 353388376
000630: *Oct  9 00:39:09.355 GMT: ISAKMP:(2768): seq. no 0x240F5391
000631: *Oct  9 00:39:09.355 GMT: crypto_engine: Encrypt IKE packet
000632: *Oct  9 00:39:09.355 GMT: CryptoEngine0: CRYPTO_ISA_IKE_ENCRYPT(hw)(ipsec)
000633: *Oct  9 00:39:09.355 GMT: ISAKMP:(2768): sending packet to a.b.c.d my_port 500 peer_port 500 (I) QM_IDLE
000634: *Oct  9 00:39:09.355 GMT: ISAKMP:(2768):Sending an IKE IPv4 Packet.
000635: *Oct  9 00:39:09.355 GMT: ISAKMP:(2768):purging node 353388376
000636: *Oct  9 00:39:09.387 GMT: ISAKMP (2768): received packet from  a.b.c.d dport 500 sport 500 Global (I) QM_IDLE
000637: *Oct  9 00:39:09.387 GMT: ISAKMP: set new node 1232564680 to QM_IDLE
000638: *Oct  9 00:39:09.387 GMT: crypto_engine: Decrypt IKE packet
000639: *Oct  9 00:39:09.387 GMT: CryptoEngine0: CRYPTO_ISA_IKE_DECRYPT(hw)(ipsec)
000640: *Oct  9 00:39:09.387 GMT: crypto_engine: Generate IKE hash
000641: *Oct  9 00:39:09.387 GMT: CryptoEngine0: CRYPTO_ISA_IKE_HMAC(hw)(ipsec)
000642: *Oct  9 00:39:09.391 GMT: ISAKMP:(2768): processing HASH payload. message ID = 1232564680
000643: *Oct  9 00:39:09.391 GMT: ISAKMP:(2768): processing NOTIFY DPD/R_U_THERE_ACK protocol 1
        spi 0, message ID = 1232564680, sa = 66290A80
000644: *Oct  9 00:39:09.391 GMT: ISAKMP:(2768): DPD/R_U_THERE_ACK received from peer  a.b.c.d, sequence 0x240F5391
000645: *Oct  9 00:39:09.391 GMT: ISAKMP:(2768):deleting node 1232564680 error FALSE reason "Informational (in) state 1"
000646: *Oct  9 00:39:09.391 GMT: ISAKMP:(2768):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
000647: *Oct  9 00:39:09.391 GMT: ISAKMP:(2768):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
And:
# show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
NEWTOWN_1841# show crypto isakmp sa
a.b.c.d   y.y.y.y  QM_IDLE           2768 ACTIVE
a.b.c.d   y.y.y.y  QM_IDLE           2365 ACTIVE
AND:
#show crypto ipsec sa | in encaps|decaps|Status|current
   current_peer a.v.d.x port 500
    #pkts encaps: 48, #pkts encrypt: 48, #pkts digest: 48
    #pkts decaps: 47, #pkts decrypt: 47, #pkts verify: 47
     current outbound spi: 0xBBF43896(3153344662)
        Status: ACTIVE
        Status: ACTIVE
   current_peer a.b.c.d port 500
    #pkts encaps: 17, #pkts encrypt: 17, #pkts digest: 17
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
     current outbound spi: 0xB8E117DD(3101759453)
        Status: ACTIVE
        Status: ACTIVE
   current_peer y.y.y.y port 500
    #pkts encaps: 65, #pkts encrypt: 65, #pkts digest: 65
    #pkts decaps: 46, #pkts decrypt: 46, #pkts verify: 46
     current outbound spi: 0x46118722(1175553826)
        Status: ACTIVE
        Status: ACTIVE
   current_peer z.z.z.z port 500
     current outbound spi: 0x167A7CD3(377126099)
        Status: ACTIVE
        Status: ACTIVE
BUT:
Tunnel3                    a.b.c.d    YES NVRAM  up                    down
Tunnel13                   a.b.c.d    YES NVRAM  up                    down
And on this router:
crypto isakmp policy 10
encr aes 256
group 5
crypto isakmp policy 15
encr 3des
group 2
c
crypto isakmp keepalive 10
crypto isakmp client configuration group jkjljkllkjkl
key ********
dns g.g.g.g.
wins sdfsddf.
pool vpn_pool
acl 108
crypto isakmp profile vpn-clients
   match identity group jkjllkklkll
   client authentication list vpn
   isakmp authorization list vpn
   client configuration address respond
crypto ipsec transform-set ESP-AES-256_ESP-SHA esp-aes 256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA_tunnel esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set ESP-3DES-SHA_tunnel
set isakmp-profile vpn-clients
reverse-route
crypto map cryptomap1 10 ipsec-isakmp
set peer a.a.a.a
match address h.g.f.d
crypto map cryptomap1 20 ipsec-isakmp
set peer r.r.r.r
match address x.x.x.x
crypto map cryptomap1 30 ipsec-isakmp
set peer gg.g.g.
match address b.b.b.b
etc .
Seems like the IPSec tunnel is up, only the GRE tunnel is down.
Try to shut/no shut the GRE tunnel on both ends.
didnt make a bit of difference...
the problem is on the asa---i just cannot find it...
From the following output:
        Status: ACTIVE
        Status: ACTIVE
        Status: ACTIVE
        Status: ACTIVE
Assuming that the above is from the spoke router, that means traffic is being encrypted, however, the router does not receive any return traffic.
What does the corresponding show cry ipsec sa shows on the ASA?
You might want to try clearing the IPSEC tunnel SA on the ASA and re-establing the tunnel, and also "clear xlate". Otherwise, feel free to open a TAC case so it can be troubleshot live with an engineer.
Cant open tac case as this device has no contract, and i would have to pay per incident.
i debugged ipsec and isakmp and got a phase 2 error---i had to debug level 200 to even see it.
cant recall the exact error, but i googled it, and basically, under the website, said to check acl--or the access list group is applied wrong.
we did not change a single entry on the remote routers, so it must be a problem on the asa itself--but i cannot find it....
i think its probably the access list group command, but not sure...
897
