ASA 5510 vpn connection issue
Hi All,
we made vpn on ASA 5510.When client connects, i see log of ASA and vpn client there is no problem in them.After connecting, i see that there is no decrypted packets in vpn client's statistics.Secure routes is seen as 0.0.0.0 0.0.0.0.
I know problem is that point, but i couldnt solve the issue.
I posted configuration below,Thanks
ASA Version 7.0(2)
names
name... ......
interface Ethernet0/0
nameif outside
security-level 0
ip address x.x.x.x x.x.x.x
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.19.60.0 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.1.1
management-only
ftp mode passive
access-list inside_nat0_outbound extended permit ip any 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 192.168.70.0 255.255.255.0
access-list deneme_splitTunnelAcl standard permit any
access-list outside_cryptomap_dyn_20 extended permit ip any 192.168.1.0 255.255.255.0
access-list deneme1_splitTunnelAcl standard permit any
access-list outside_cryptomap_dyn_40 extended permit ip any 192.168.70.0 255.255.255.0
access-list deneme_splitTunnelAcl standard permit 172.19.60.0 255.255.255.0
access-list deneme1_splitTunnelAcl standard permit 172.19.60.0 255.255.255.0
access-list 15 extended permit ip 192.168.70.0 255.255.255.0 172.19.60.0 255.255.255.0
access-list 15 extended permit icmp 192.168.70.0 255.255.255.0 172.19.60.0 255.255.255.0
group-policy deneme internal
group-policy deneme attributes
split-tunnel-policy tunnelspecif deneme_splitTunnelAcl
webvpn
group-policy deneme1 internal
group-policy deneme1 attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value deneme1_splitTunnelAcl
webvpn
ip local pool gezi 192.168.70.0-192.168.70.255 mask 255.255.255.255
username xxx password xxx privilege 0
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication telnet console LOCAL
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp
crypto ipsec transform-set TOLGA esp-3des esp-none
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 172.19.0.91 255.255.255.255 outside
ssh 172.19.0.71 255.255.255.255 outside
ssh 172.19.0.61 255.255.255.255 outside
ssh 172.19.0.78 255.255.255.255 outside
ssh 172.19.0.212 255.255.255.255 outside
ssh 172.19.0.243 255.255.255.255 outside
ssh 172.19.60.170 255.255.255.255 outside
ssh timeout 5
console time deneme type ipsec-ra
tunnel-group deneme general-attributes
default-group-policy deneme
tunnel-group deneme ipsec-attributes
pre-shared-key *
tunnel-group deneme1 type ipsec-ra
tunnel-group deneme1 general-attributes
address-pool POOLVPN
default-group-policy deneme1
tunnel-group deneme1 ipsec-attributes
pre-shared-key *
Silver
Re: ASA 5510 vpn connection issue
Upgrade the code to a interim version 7.2.1.9.Make sure crypto access-lists match on both the sides.Else there will be connection drop.
In your NAT Exemption, Split Tunnel and Interesting traffic ACL's, do not use 'any.' Be more specific.
Your dynamic maps dont need to reference an ACL. A dynamic crypto map doesnt know the source ip address anyway.
Add the following line to your config for routes to be injected into the ASA when users connect.
'crypto dynamic-map outside_dyn_map 20 set reverse-route'
'crypto dynamic-map outside_dyn_map 40 set reverse-route'
100
