Community Member
ASA VPN to LAN not working
I am trying to set up a SsL VPN on this ASA5510. I can get to the web portal by going to http://xx.xx.xx.211 I can login as my test user, and I am able to ping, telnet and RDC using the web-portal.  When I connect to the using https://xx.xx.xx.211:10443 or xx.xx.xx.211 and AnyConnect I am not able to ping, telnet or RDC.
I am connecting via a Mac OSX 10.7 and also a Window 7 Pro machine
I am  authenticating via a local username and password on the 5510..
I am using SSL and not IPSEC
Thanks all
I can post my config again if that would help.
I have also connected a PC directly to the E/1 interface and I can ping and RDC to that PC using the Anyconnect client and xx.xx.xx.211 public IP. When connected into the LAN via a 3760 that is when I can't connect to anything via Anyconnect but I am able using the Web-Portal. Also when connected to the LAN there is a sonicwall NSA 2400 might that be interfering wit AnyConnect?
Everyone's tags (1)
54
