ASDM v1.5(20) fails to connect
larksys12
I'm using ASDM v1.5(20) to access my ASA 5510 remotely.  I get the error "Unexpected end of file from server".  It appears that I have upgraded my java environment and ASDM doesn't like it.  What can I do.  I can't tell you what firmware version I'm running on the 5510 because I can't get to it but it is definitely a back version.  What are my options?  I know the device is online and accessible locally. I just don't have anyone there that can do that for me right now.  I'd like to eliminate this problem in the future.
7 Replies 7
cadet alain
if you can't connect through ssh then downgrade Java version and try again.
Regards.
Alain
I have backed up to jre6.  Where do I need to be?
I don't understand what you mean ?
Didn't you have a JRE version which was working before?
Regards.
Alain
Yes, and I would swear that it was v6.  But I do a lot of development on this machine.  I only have v6 and v7 installed.
Are you running this one ?
http://www.java.sun.com/products/archive/j2se/6u7/index.html
if not can you try it and also tell us version of ASDM as this is the launcher version you gave.
Regards.
Alain
I'm not sure why, but there is no ASDM launcher on the local PC attached to the ASA 5510.  Is there a CLI I can use?
you can configure the ASA with CLI by either connecting a console cable or using  the management interface.
Regards.
Alain
