AUX ASYNC CONNECTIVITY FOR ACCESSING OFFICE NETWORK
I want to configure router auxiliary port with modem for accessing the Office network resources from home using PSTN line.
I have configured the auxiliary port 0 with following configuration
line aux 0
exec-timeout 0 0
modem InOut
modem autoconfigure discovery
transport preferred none
transport input all
transport output all
autoselect during-login
autohangup
stopbits 1
speed 115200
flowcontrol hardware
The async port configuration is as follows:
interface Async65
ip unnumbered fastEthernet0/0
encapsulation ppp
async default routing
async mode interactive
peer default ip address 192.168.1.206
ppp authentication chap
end
I have configured username cisco with password cisco for ppp chap authentication.
When i dial from my laptop (windows xp professional)the connection is not established and it is stuck to the verifying usernam and password screen.
The same configurtion works if i access router exec prompt. Am i missing something. I don't see any logs when i do debug for ppp on router.
Is there any solution for achieving it ( accessing network shares and accessing files in the LAN connecting through auxiliary port).
The router i am using is 2621xm with 12.3(6c) image.
please help
regards
gaurav
Blue
Re: AUX ASYNC CONNECTIVITY FOR ACCESSING OFFICE NETWORK
YES,
you should be able to setup IP connectivity via the AUX port and dial-in from the PSTN.
to verify your configuration:
please see the following link for more AUX Port dial-in connectivity configuration info:
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080093c31.shtml
or for ppp multilink:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008009455a.shtml
Thanks for the reply.
I checked the configuration done on the router is correct. I am not able to crack where the actual problem lies. whtehre it is the dialer configuration on the windows xp machine. Do i need to add any ppp script to connect to the router?
Please help
regards,
gaurav
193
