BRI/PRI directly to a console port
I would like to know if it's possible to connect a BRI or PRI serial interace to a console port to raise up an async line.
I already know that there are various possibilities when we use Aux ports like a modem and attach serial ports to it. Can this be done using something like "modem inout" or "modem enable" in the console line?
We are going to use Cisco 4000 and 2500 and by the moment we can't buy more async port modules, so this could be a solution, if supported.
Re: BRI/PRI directly to a console port
AFAIK i don't think you can connect your bri or pri line onto your console port.
regds
I dont think we can do so . product speficications would also help . but again i dont think so ...
102
