12-07-2005 01:19 AM
Hi, i m having 7206-VXR with BRI S/T ports and i m terminating one BRI line in that. But the Layer 1 status shows Deactivated. But it becomes Active when we call the number from phone line.
When we tested the same line to ISDN Telephone thro. the same NT, we are able to make calls in the same line.
But when we connected to router it shows Layer1 Deactivated and becomes ACTIVE when we call from our phone line.
show isdn status
Global ISDN Switchtype = primary-net5
ISDN BRI3/0 interface
dsl 16, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 65, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Activated dsl 16 CCBs = 0
The Free Channel Mask: 0x80000003
show runinterface BRI3/0
description BRI NO. xxxxxxx
no ip address
no ip directed-broadcast
isdn switch-type basic-net3
thx in Advance!
Balaji .V
12-07-2005 02:08 AM
have you tried connecting the same onto other port ?
also have u tried manually dialing from the router cli ??
do revert whether you have configured this bri as a backup for any other link if yes do check out for some backup delay or other backup related commands under that interface.
also check out for some floating static routes with higher admin distance than the primary one which will also supresst he bri in making calls out..
if possible post out the whole config here...
regds
12-07-2005 03:13 AM
Prem,
Yes, we tried connecting to other ports, but the status is same.
i haven't tried. i m just looking the status to be ACTIVE.
Yes it is for backup. As a primary line, we have E1.(2MB).
There is no floating static as such. Even if it is there, the status should show Active in the normal cirucumstances. Becz with the same config in other locations, it seems to be ACTIVE with layer two Multi-framed.
sorry!
As i pasted part of the interface config, only switch-type is configured in all our boxes.
12-07-2005 04:32 AM
there is another post in this forum from somebody who has the same problem, this is what I found:
I found the following bug, which might apply to you:
Symptoms: An outgoing Basic Rate Interface (BRI) call fails to activate the
layer 1.
Not sure which IOS version you are running, but the fixed versions are:
12.4(3.6), 12.4(3.6)T, 12.3(11)T08, 12.3(16.7), 12.4(03a)
Can you try and load any of these IOS releases ?
GP
12-07-2005 08:52 PM
Thx for your reply,
This is Version 12.0(31)S. It should work in that version becz in all of our other places it is working with same IOS and same Interface config.
Balaji. V
12-08-2005 03:34 AM
Perhaps is obvious, but
Have you tried to exchange one router with one of the others ( similar as you've said ) and see what it happens ???
FA
12-08-2005 04:13 AM
it is not possible, since they are 300km away and other customers are there. but this is log i m getting on that router while calling from my mobile
Dec 8 12:37:56 IST: ISDN BR3/0: Recvd MPH_IIC_IND from L1
Dec 8 12:37:57 IST: ISDN BR3/0: L1 is IF_ACTIVE
Dec 8 12:37:57 IST: LIF_StartTimer(): t->Prim is NULL
Dec 8 12:37:57 IST: ISDN BR3/0: TX -> SABMEp sapi = 0 tei = 65
Dec 8 12:37:57 IST: ISDN BR3/0: RX <- UAf sapi = 0 tei = 65
Dec 8 12:37:57 IST: %ISDN-6-LAYER2UP: Layer 2 for Interface BR3/0, TEI 65 changed to up
Dec 8 12:37:57 IST: ISDN BR3/0: RX <- UI sapi = 0 tei = 127 i = 0x08013805A104038090A31801896C0C018339323832313739303637700BA134323132343833353935
Dec 8 12:37:57 IST: SETUP pd = 8 callref = 0x38
Dec 8 12:37:57 IST: Sending Complete
Dec 8 12:37:57 IST: Bearer Capability i = 0x8090A3
Dec 8 12:37:57 IST: Channel ID i = 0x89
Dec 8 12:37:57 IST: Calling Party Number i = 0x0183, '
Dec 8 12:37:57 IST: Called Party Number i = 0xA1, '
Dec 8 12:37:57 IST: ISDN BR3/0: Incoming call id = 0x4D
Dec 8 12:37:57 IST: ISDN BR3/0: received HOST_INCOMING_CALL call_id 0x4D
Dec 8 12:37:57 IST: ISDN BR3/0: Event: Received a call id 0x4D with a bad bearercap from
Dec 8 12:37:59 IST: ISDN BR3/0: RX <- IDCKRQ ri = 0 ai = 127
Dec 8 12:37:59 IST: ISDN BR3/0: TX -> IDCKRP ri = 38651 ai = 65
Dec 8 12:38:01 IST: ISDN BR3/0: RX <- UI sapi = 0 tei = 127 i = 0x08013805A104038090A31801896C0C018339323832313739303637700BA134323132343833353935
Dec 8 12:38:01 IST: SETUP pd = 8 callref = 0x38
Dec 8 12:38:01 IST: Sending Complete
Dec 8 12:38:01 IST: Bearer Capability i = 0x8090A3
Dec 8 12:38:01 IST: Channel ID i = 0x89
Dec 8 12:38:01 IST: Calling Party Number i = 0x0183, '
Dec 8 12:38:01 IST: Called Party Number i = 0xA1, '
Dec 8 12:38:01 IST: ISDN BR3/0: Incoming call id = 0x4E
Dec 8 12:38:01 IST: ISDN BR3/0: received HOST_INCOMING_CALL call_id 0x4E
Dec 8 12:38:01 IST: ISDN BR3/0: Event: Received a call id 0x4E with a bad bearercap from
Dec 8 12:38:07 IST: ISDN BR3/0: RX <- RRp sapi = 0 tei = 65 nr = 0
Dec 8 12:38:07 IST: LIF_StartTimer(): t->Prim is NULL
Dec 8 12:38:07 IST: ISDN BR3/0: TX -> RRf sapi = 0 tei = 65 nr = 0
Dec 8 12:38:12 IST: ISDN BR3/0: RX <- DISCp sapi = 0 tei = 65
Dec 8 12:38:12 IST: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR3/0, TEI 65 changed to down
Dec 8 12:38:12 IST: ISDN BR3/0: TX -> UAf sapi = 0 tei = 65
Dec 8 12:38:42 IST: ISDN BR3/0: Physical layer is IF_DOWN
Dec 8 12:38:42 IST: ISDN BR3/0: Shutting down ME
Dec 8 12:38:42 IST: ISDN BR3/0: Shutting down ISDN Layer 3
Any idea!
12-08-2005 05:10 AM
the ´bearercap´ messag ein your debug output could mean that somehow the router is not recognizing the type of connection made. It might be worth looking at the configurations from both sides, can you post those, if possible ?
GP
