BRI-to-PRI Connectivity issues
I'm having some serious BRI-to-PRI connectivity issues, and I was hoping someone out there could offer some assistance. The devices call one another perfectly, but they just both send magic numbers out and never get the data from the other device so they are unable to setup a layer to connection. We're using 804 series routers to dial into a PRI running on a 2811. Here's the configurations running on the 804 -
sh run
Building configuration...
Current configuration : 601 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
isdn switch-type basic-ni
interface Ethernet0
no ip address
shutdown
interface BRI0
ip address 172.16.213.2 255.255.255.252
encapsulation ppp
dialer map ip 172.16.213.1 speed 56 7349291319
dialer-group 1
isdn spid1 73492960780101
isdn spid2 73492960790101
isdn incoming-voice data
ip http server
ip classless
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
end
And on the t1 and serial of the 2800 series.
interface Serial0/2/1:23
no ip address
dialer pool-member 1
isdn switch-type primary-ni
no cdp enable
end
interface Dialer1
ip address 172.16.213.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name Router
dialer string 7349296078 class 56
dialer caller 7349296078
dialer caller 9296078
dialer caller 7349296079
dialer-group 1
peer default ip address 172.16.213.2
fair-queue
end
I've tried using encapsulation ppp on the s0/2/1:23 interface, but it drops connectivity with the CO as soon as I type the command. Any help someone could offer would be excellent as we're all stumped around here.
Steve
Re: BRI-to-PRI Connectivity issues
Anyone? Still arguing with phone company over who's problem this is. Any insight would be greatly appreciated.
Steve
Steve,
I have seen this issue many times before and it always turned out to be an issue on the Telco network. It's quite possible either the line itself or some equipment on the provider network mayn't be provisioned for DATA or faulty equipment on their network.
Let us know how you do with it.
Sundar
So I thought everyone might be ineterested in the final solution to this issue. We ended up having to upgrade to IOS version 12.4(9T) or higher becuase we were attempting to use a VWIC with data calls. VWICs only supported voice traffic until release 12.4(9T) and the new dial peer data command.
Thanks!
Steve
238
