Bypass BGP traffic + IPsec tunnels + Cisco 2851 router
Hi All ,
We have internet link from local ISP to one of the site over which Ip sec tunnels are formed to main service provider..
Due to high utilization of the link , we seeing tunnel flap which in-turn flapping BGP...
IS there any way to bypass BGP traffic using acl's so that BGP won't flap in case of High utilization of the internet link ?
Tunnel 100 and tunnel 200 are configured on site router as well on VAS gateway routers of Main service provider.
Thanks , M S K
1 REPLY
Hello.You may either increase
Hello.
You may either increase BGP intervals or protect BGP traffic with QoS (on both sides).
Do you use crypto map, or VTI?
117
