Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cable modem to 2600 to wireless rtr
I am looking at running the cable modem connection to a 2950 (outside vlan)and on the same vlan plug in the f0/0 interface of the 2600. Then plug the f0/1 interface in vlan (inside) of the 2950.
The issue I wonder about is DHCP address from the ISP. I there an IOS command to have the f0/0 interface on the 2600 pick up the DHCP address??
1 REPLY
Re: cable modem to 2600 to wireless rtr
You can try ip address dhcp command under the ethernet interface to pick the ip from the SP IP Pool..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tiad_r/adrdhpht.htm#wp1132730
regds
126
