callback problem between Cisco router and MS XP client
I am configuring callback between a cisco 3725 router and a dialup Microsoft XP client.
Here is the router configuration :
aaa new-model
aaa authentication login userauthen local
aaa authentication ppp default local
aaa authorization network groupauthor local
chat-script offhook "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT\T" TIMEOUT 60 CONNECT \c
username test callback-dialstring "" password xxx
interface Loopback0
ip address 172.20.8.1 255.255.255.0
interface Serial0/1
physical-layer async
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 0 either
dialer-group 1
async mode dedicated
peer default ip address 172.20.8.200
keepalive 40 3
ppp callback accept
ppp authentication pap chap callin
ppp authorization groupauthor
dialer-list 1 protocol ip permit
line 2
script modem-off-hook offhook
script callback callback
login authentication userauthen
modem InOut
modem autoconfigure discovery
transport input all
autoselect ppp
speed 115200
flowcontrol hardware
Here is problem :
- Without the command ppp callback accept, the ppp connection works properly
- When enabling callback, the client and the router agree on callback, the router disconnects and then reconnects, the interface comes up and then the router sends several CONFREQs with no response before disconnecting.
In the meanwhile, running windump on the calling client, shows that the client itself sends 8 CONFREQs with no response from the router. I tried with a Win 98 client and the behaviour is the same (from the router side at least).
Could you have a look at the configuration and tell me where the problem comes from ?
Thank you in advance.
  • Remote Access
1 REPLY
Silver
Re: callback problem between Cisco router and MS XP client
A PC user (client) connects to the Cisco access server.
Callback process is negotiated in the Point-to-Point Protocol (PPP) link control protocol (LCP) phase.
PPP authentication is performed.
The Cisco IOS software validates callback rules for this user or line and disconnects the caller for callback.
The Cisco access server dials the client.
There are four types of MSCB:
No callback.
User-specified callback number.
Server-specified (preconfigured) callback number.
List of preconfigured callback number
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094338.shtml
101
