Can't figure out my telnet problem from 871
Hi all,
I have built a CCNA home lab consisting of:
1. 871 - Fe4 connected to my ISP router and acting as my home lab GW and switch (Office 1 GW and switch).
2. 2610 - e0/0 connected to my 871 switch side Fe0 and acting as a serial GW to office 2. And,
3. 2610 - acting as office 2 GW, s0/0 connected through serial to office 1 2610 s0/0.
(ISP Router)-------------(871)-------------(2610)<><><><><><><>(2610)
The problem I am having is I can't telnet from the 871 to any of the 2610s but can telnet from any 2610 to the 871.
Pings from any node (871 and 2610s) to all interfaces are successful.
This is my 871 config:
Building configuration...
Current configuration : 2407 bytes
version 12.4
no service pad
service password-encryption
hostname GW_871
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$c6Pf$9CKwXssj5sv8kXx5WcYsN1
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool VLAN1_POOL
   import all
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   dns-server 65.183.0.76
ip dhcp pool VLAN10_POOL
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
ip dhcp pool VLAN20_POOL
   import all
   network 20.20.20.0 255.255.255.0
   default-router 20.20.20.1
ip dhcp pool VLAN30_POOL
   import all
   network 30.30.30.0 255.255.255.0
   default-router 30.30.30.1
ip cef
ip name-server 65.183.0.76
no ipv6 cef
archive
log config
  hidekeys
interface FastEthernet0
duplex full
speed 10
interface FastEthernet1
switchport access vlan 10
interface FastEthernet2
switchport access vlan 20
interface FastEthernet3
switchport access vlan 30
interface FastEthernet4
description *** LINK TO ISP ***
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description *** LINK TO OFFICE 1 GW ***
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Vlan10
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 20.20.20.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 30.30.30.1 255.255.255.0
ip nat inside
router rip
version 2
redistribute static
network 10.0.0.0
network 20.0.0.0
network 30.0.0.0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 10.0.0.0 0.0.255.255
control-plane
line con 0
password 7 094F471A1A0A
logging synchronous
login
no modem enable
line aux 0
password 7 05080F1C2243
logging synchronous
login
line vty 0 4
logging synchronous
login
transport input telnet
scheduler max-task-time 5000
end
Please help.
Thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Thanks. If it will not allow removal of the ip nat statement then try removing ip nat outside from the Ethernet0/0 interface.
Rick
Am I correct in understanding that the 871 can ping to the address of the 2610 to which you are attempting telnet? If ping from 871 to that interface is successful and telnet then fails to the same address then the problem is not a routing or IP connectivity issue.
If there is IP connectivity and telnet fails it is much more likely to be an issue in the configuration of the 2610 than it is to be an issue in the 871. Can you provide the configuration of the 2610?
Rick
Yes correct. 871 can ping both 2610s.
Here is the directly connected 2610 config:
Current configuration : 939 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname O1GW_2610
enable secret 5 $1$3tl3$OZbMdGob8IIWRri40oMbI0
ip subnet-zero
call rsvp-sync
interface Ethernet0/0
description *** TO OFFICE 1 LAN ***
ip address 10.0.0.10 255.255.255.0
ip nat outside
full-duplex
interface Serial0/0
description *** LINK TO OFFICE 2 ***
ip address 10.0.10.1 255.255.255.0
ip nat inside
router rip
version 2
network 10.0.0.0
no auto-summary
ip nat inside source list 1 interface Ethernet0/0 overload
ip classless
ip http server
dial-peer cor custom
line con 0
password 7 030752180500
logging synchronous
login
line aux 0
logging synchronous
login
line vty 0 4
logging synchronous
login
end
So from the 871 ping to 10.0.0.10 works ok but telnet to 10.0.0.10 fails?
As a test would you remove this line from the config of the 2610
and see if the telnet behavior changes?
Rick
Yes that is correct Rick.
But trying to remove the line: ip nat inside source list 1 interface Ethernet0/0 overload
gives the error: %Dynamic mapping in use, cannot remove
I also tried removing the access-list before but I receive the same error.
Rick
Re: Can't figure out my telnet problem from 871
I removed ip nat outside from e0/0 and now its works!!!
Thanks Rick!!!
So the "ip nat outside" statement is only used on the interface on a router going to the internet then? Like the GW router?
I am glad that my suggestion helped you to solve your problem.  I have seen some situations where nat outside impacted the ability to telnet to a router and this seems to be one. The answer to the question of where do you use ip nat outside has potential to get a bit complex. Basically you use it on the outbound interface of a router where you need to do address translation. The most common of these would certainly be on the interface of a router going to the Internet. But there might be some other situations where you want to do address translation. For example there might be office 1 and office 2 of a company that happen to use the same address range (perhaps as the result of an acquisition or merger) and you would need to do address translation if they need to communicate with each other.
Thank you for using the rating system to mark this question as answered (and thanks for the points). It makes the forum more useful when people can read about a problem and can know that a solution was found. Your marking this question has contributed to that process.
Rick
1118
