CEF LoadBalance on 2 ADSL connections
prachaya_k
Hi there, Can anyone help me with CEF load balance. I have 2 ADSL connections on the router 2811 and I am trying to load balance over these 2 links. Please see the attachment for my current configuration. The problem is I tried to browse the internet some website is not accessible and if it can access it take a long time to change from page to page. What is the problem here? I understand that the router see the 2 default route with the same cost and CEF will load balance the traffic using per-destination by default.. But the problem is exists.. Anyone has any idea what I did wrong..
Thanks in advance..
3 Accepted Solutions
paolo bevilacqua
Under both dialer interfaces:
ip mtu 1492
Under FastEthernet0/0:
ip tcp adjust-mss 1452
Optionally:
sub-interface are not needed with PPPoE
PPP header is 8 bytes. IP and TCP header togethers are 40. From that the simple math.
All seems good, try configuring an host route so that the FTP server is reached using one interface only.
10 Replies 10
paolo bevilacqua
ip mtu 1492
Optionally:
Great!! Woring perfectly...  Thank you very much.. Could you kindly explain how to calculate MTU on Dialer interface and ip tcp adjust-mss 1452 on Fa0/0. Or any link to document related to this problem will be really appretiated...
Thanks a lot p.bevilacqua , just a few more question on why do I need to recalculate this MTU, in what scenario that need to do this? I mean if I were to use other type of WAN connection e.g. ISDN VPN MPLS FramRelay, will I need to adjust these MTU? If it need to adjust MTU then it will always minus 40 bytes due to IP and TCP heade and plus addition MTU from WAN technology, is this correct?
Each case is different, you have to test first.
The second commnd is the TCP MSS, not MTU. It is not always necessary, only when there are problems.
The same problem appear when user were trying to use FTP to FTP server on internet. Do you have any idea what could be the problem here? Internet web browsing is fine only FTP connection is a problem. What happen is some user able to log on and get file from FTP server while some user cannot log on at all. What else might be nessesary except from adding MTU 1492 on Dialer interface and ip tcp-mss 1452 on fa0/0.
Thanks.
Prachaya
Post configuration again.
p.bevilacqua..  Again thanks for your help. Please see the current configuration file.
Prachaya
Hi,,
I also have 2 Internet Connections, both are DSL, I have Cisco 1811 router which has 2 WAN ports and 8 L2 Ports, I want to configure my both internet connections for load balancing as well want to connect soft VPN,
I viewed your configuration, you used dialer interfaces with ATM interface configured,,,
My question is .. why you configured ATM interface?
Can I use your configuration for this purpose?
Please Advise
Junaid
