Webcast-Catalyst9k
Cisco 1712 IPSec VPN connection stalls
Hi all,
i got stuck in configuring a cisco 1712 with a vpn tunnel.
Problem: after the two endpoints are connected (IPsec tunnel), i tried to do
an ftp upload to the other side. As soon as 32kByte of data where transfere
d, the connection stalls or stops.
I don't know what could be debuged or configured to eliminate this problem.
Any help would be wellcome.
Thanks.
Juergen
--- config ---
version 12.3
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
no service dhcp
hostname vpn02
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
clock timezone MET-1 1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip cef
no ip domain lookup
no ip bootp server
ip ips po max-events 100
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
no ftp-server write-enable
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
crypto isakmp key <SOMEKEY> address <SOMEADDRESS>
crypto isakmp ccm
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map CMAP_1 1 ipsec-isakmp
set peer <SOMEADDRESS>
set transform-set ESP-3DES-SHA
match address 100
interface Loopback0
ip address <DSL-ADDRESS>
interface BRI0
no ip address
shutdown
no cdp enable
interface FastEthernet0
no ip address
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
traffic-shape rate 1984000 49600 49600 1000
arp timeout 60
no cdp enable
interface FastEthernet1
description VLAN1 Interface
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
no cdp enable
interface Vlan1
ip address 10.10.1.5 255.255.0.0
interface Dialer1
ip unnumbered Loopback0
ip mtu 1492
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname <SOMEHOSTNAME>
ppp chap password 0 <SOMEPASSWORD>
ppp pap sent-username <SOMEHOSTNAME> password 0 <SOMEPASSWORD>
crypto map CMAP_1
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http access-class 10
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
access-list 10 permit 10.10.0.0 0.0.255.255
access-list 100 permit ip 10.10.0.0 0.0.255.255 192.168.168.0 0.0.0.255
access-list 100 remark IPSec Rule
access-list 101 permit ip 10.10.0.0 0.0.255.255 192.168.168.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
Re: Cisco 1712 IPSec VPN connection stalls
Hello Jurgen,
Hope you will find the following links helpful:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_tech_note09186a0080093f1f.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087ae1.html
They describe common problems with tunnels and one of the proposed solutions might work for you.
Leo
Helle Leo,
thanks a lot for your links.
The df bit override functionaltiy does the trick.
Juergen
293
