Cisco 2600 ISDN to a Netscreen for backup
We are trying to establish a backup solution using ISDN for an ISP failure at our remote sites. At our remote sites, we currently have several flavors of Netscreen firewalls. According to Juniper, they support failover on the serial interface using ISDN to dial into an ISP. We have set up a Cisco 2600 with a PRI at our main location that will simulate an ISP router. Upon failure of the primary Untrusted connection on the Netscreen, it forces the ISDN TA (MultiTech MTA128NT) to dial the appropriate number and begin PPP negotiations. LCP never completes and the connection gets dropped. I have included the debug ppp negotiations output. Any ideas.
Jack Farrer
Re: Cisco 2600 ISDN to a Netscreen for backup
HI
hope this helps..
http://cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a008019cfa7.shtml
also if possible do post debug outputs of q931 and q921 logs...
regds
I read through this document, but didn't find anything that helps. I have also included the debug isdn q921 and q931 output.
Jack Farrer.
Dec 1 23:03:02.471 UTC: %LINK-3-UPDOWN: Interface Serial1/0:0, changed state to
down
Dec 1 23:03:02.475 UTC: Se1/0:0 PPP: Authorization NOT required
Dec 1 23:03:02.475 UTC: Se1/0:0 PPP: No remote authentication for call-in
Dec 1 23:03:02.475 UTC: Se1/0:0 PPP: Phase is ESTABLISHING
Dec 1 23:03:02.475 UTC: Se1/0:0 PPP: Sending Acct Event[Down] id[95]
As per the Debug message, I understand its an Authentication / PPP issue.
Could you please paste the debug ppp authentication as well please along with the debug isdn q931 and sh isdn status
That would certainly help us to resolve the issue.
Wilson Samuel
Samuel,
I have attached the requested information. Let me know what you think.
Jack
Hi Jack,
Problem seems with the authentication, you need to chaeck once again username and password on both end router. then give a test call. as per your debug test result every time it is stuck in authentication phase. please remove the earlier username or try to find out the password configured in both side, it should be same on both end.
pls try below one.
for e.g.
On ROUTER A
username ROUTERB password cisco
on ROUTER B
username ROUTERA password cisco
if it helps, otherwise please paste both end config.
Regards...Mukesh
358
