Cisco 2620 Adsl WIC
My 2620 will not recognise a ADSL WIC card. I have tried a number of ios but none work. Also I have 8mb of flash on my router and some bin files less than that size will not load using xmodem saying there is not enough space. Any ideas on how to get the router to see the card will be greatly appreciated
1 REPLY
Purple
Re: Cisco 2620 Adsl WIC
Quoting from CCO:
"The Cisco 2600/3600/3700 series routers require a PLUS Cisco IOS Software image for ADSL if version 12.2T is in use. From Cisco IOS Software Release12.3 mainline and later, ADSL WIC support is available in the "IP Base" feature set."
So you will need to download an appropriate image to get your router to recognise the card. Since you only have 8Mb of Flash, you will either need to upgrade your flash to 16Mb or boot via TFTP.
Hope that helps - pls rate the post if it does.
Paresh
223
