Cisco 2811 not going ahead from Switch:
Router Details :
model number Cisco 2811
With switch model detail- NME-16ES-1G-P
PROBLEM FACING:
once if you switch from router to switch its showing as
Switch :
1 ACCEPTED SOLUTION
Re: Cisco 2811 not going ahead from Switch:
To download an image you need a valid Cisco contract which i think you have.
The EtherSwitch service modules support the same Cisco IOS Software images as the Catalyst 3750 and Catalyst 3750-E Series Switches
YOu can download the image to the router flash and then do an xmodem to transfer it to the ether switch module.
Have a look at the software section in the below link
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd8028d16a_ps5855_Products_Q_and_A_Item.html
Narayan
It seems that the etherswitch module image is corrupted.
Have a look at this link to recover a corruspted image
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/miragenm.html#wp1768057
Narayan
Want to ask you following question:
Is the ether switch module image/IOS loaded in the same flash where router image/IOS is loaded.
How can I download the image from the cisco link?
Could you provide me the ether switch image name specific to 2811 router.
I have already tried downloading the correct image from the Cisco site using software advisor, but couldn't find the correct image.
Pls Help
Rgds,
Ashish
Narayan
Can I download any of Cat3750 or Cat3750-E series IOS and upload the same in the router flash ?
Rgds,
Ashish
yes (above 12.2(25)EZ) as long as you have a valid Cisco contract..
Narayan
I ve downloaded c3750-ipservicesk9-mz.122-46.SE
do you think it will work.
Rgds,
Ashish
yes.
follow the recovery procedure link posted earlier
Narayan
Thanks Narayan,
The issue got resolved.Thanks a tonne once again for all your support and valuable help.
Ashish
319
