Community Member
Cisco 2821 with VWIC-2MFT-E1for dialin purposes Help
Hi All,
I'm working in a new project to configure a cisco 2821 with a VWIC2-2MFT-E1 interface card to work as a RAS server (Dial Backup). I will not use this card for voice purposes justo for data transmission.
I'm searching for a document like "how to" to configure this equipment, and I don't know if I have all necessary hardware to do this.
My IOS: c2800nm-ipvoicek9-mz.124-13a.bin
SHOW DIAG:
sh diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11010EJC
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-02
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20070106
Chassis Serial Number : FTX1103A3HA
Chassis MAC Address : 0019.3008.2900
MAC Address block size : 32
CLEI Code : COM3D00BRA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-04
Version Identifier : V03
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 31 30 31 30 45 4A 43 40
0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 02 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 3E DA C2 8B 46 54 58 31 31 30 33
0x40: 41 33 48 41 C3 06 00 19 30 08 29 00 43 00 20 C6
0x50: 8A 43 4F 4D 33 44 30 30 42 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
0x70: 04 89 56 30 33 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8539-05
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC105234P5
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
Version Identifier : V01
0x00: 04 FF 40 03 EE 41 04 00 82 49 21 5B 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 35 32
0x20: 33 34 50 35 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 33 32 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10412SU3
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 41 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 30 34 31 32 53 55 33 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
Is anybody here has some experience and can help me with some information?
My best regards
Adriano
Silver
Re: Cisco 2821 with VWIC-2MFT-E1for dialin purposes Help
Hi, with the vwic card you can only use isdn pri signaling for voice connections, not for data. You can see it at the cco:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
So for your purposes you'll need another equipment like a network module NM-1CE1T1-PRI
Hope this helps, if so pls rate post
Bronze
Actually, now you should be able to do data/DDR on VWICs as well, thanks to this new 12.4 feature :
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124newft/124limit/124x/124xc4/intserv.htm
Thanks and Regards,
~Zulfiqar
Community Member
Thanks all for the help,
In fact, I will use 2 E1's for this projetct from Telefonica.
I will verify all these information with my Cisco Partner here in Brazil.
Adriano Porcaro
328
